I'm looking for some guidance of what to look for - I rebuilt 3 working flippers on my Whirlwind. The Right ones turned out fine, initially, but the left one was quite weak. I thought perhaps I had the wiring wrong as regards the power wires to the ends, tried reversing those. That didn't work at all; flipper was dead. Tried re-reversing them; flipper still dead and R sided flippers working but acting weaker and chattering some since then.
I checked Ohm resistance on the 3 lugs and the meter goes from infinity to zero when I make contact between either outside lug and the middle, or between the two outside lugs. I think this is good , that the coil wires haven't lost contact with the lugs (with all the soldering I did), but am not sure.
Additionally, does polarity matter as regards the two power wires which are hooked up to the outside two lugs? What happens if they are reversed? Could I have blown a fuse if the R sided flippers are still working some?
Thanks.
