Hi, and thanks in advance for any help with this issue and sorry for any obvious newb questions or terminology and especially if this has been covered before (I searched the forum, but didn't find anything).
I have a Data East Time Machine that has been working problem free for over two years. A couple months ago the machine stopped working with an accompanying electrical burning smell. I discovered the source was the right pop bumper coil. I pulled the plug until I had time to deal with it and here I am.
So far, I diagnosed and replaced the TIP36C that shorted out causing the coil stick and burn (many blown fuses to determine the problem).
I've got it all back together and this is the current state of the machine:
-All pop bumpers and both slingshots are not working.
-No fuses are blowing (that's good)
-The sound seems to be working but I don't think 100%. I seem to remember there was some intro music.
-There is a ground hum that I have to find the source of.
-Some lamps are working and some are not, namely the top bank on the backglass and the three 5k trough lights as the top of the board (closest to the backglass)
So when I run the diagnostic tests, I notice the following:
-The Gen ILL Relay doesn't sound like it's clicking
-Flash 7, 8 & 9 don't seem to work (maybe symptomatic of the lamps issue above)
-When the test get to the LS Kick, the lights flash/dim and the test stops. The game resets.
I have checked the wiring to all the coils in the circuit, looked for pinched wires, etc. I've removed and reseated all the connectors on every PCB. I tested a suspect diode on the left slingshot (seemed ok).
I'm stumped. Hoping some kind soul out there with any idea of what to look for, can shed some light on this for me.
Mike B
