Have an odd problem with my Data East Star Wars machine that I'm hoping someone may shed some light on. When a ball goes into the "Force" scoop (called the left scoop in the manual), it immediately triggers the left VUK to fire 6 times (quickly -- it's empty) and then the machine comes back and fires the ball up out of the scoop. The switches all appear to be fine (it scores normally and I've run the diagnostics on every switch/coil on the machine...all test good). I've checked all of the fuses and they all test good. The game is playable as-is...but it's very odd. Also...possibly unrelated, but at the same time the Force scoop started behaving weird, I noticed that the left "Taun Taun" light stays lit all the time during game play.
The game used to work fine, btw, until I upgraded the power board (to xPin) and the sound board (Pinsound). At the same time I also swapped out a ball trough switch that was acting flaky. So somewhere in the midst of monkeying with it I appear to have messed with something that I can't figure out.
Any thoughts on what to check out would be appreciated.
