Traded an email or two with Vid on a DE SW Cabinet Restore. Posting here, so that he can comment; and others may benefit.
The situation/background:
DE SW -Game was sold to me as a players game, so I knew it was rough. I've fixed cleaned up all the playfield issues, but the cabinet is still in pretty bad shape. My wife would like me to keep it, so i can't trade this headache away.
I just received a set of scanned decals from Europe, so it's time to start bitting the bullet and work the cabinet.
Problems:
The cabinet looks like it sat without legs in storage, and the underside was exposed to water. On each side, wood is delaminating or chipping off. The bottom of the cabinet was so wet, that the particle board is now "fuzzy" and droops a bit.
I've got a plan for most of the fixes:
- Fix the delimitation with wood glue or epoxy. Bondo any chips/gaps (i've done some other cab repairs with excellent results, so not as worried here; but i will always take suggestions)
- Take the decals and have the paint match the color of the decals.
- Cut out the bottom and replace with a new plywood board.
A few questions:
- I have not found a lot of detail about pulling and replacing the bottom wood panel. When i am done i want it to be close to factory. Anyone have any examples and steps they used to do it? Getting the panel out is not a problem. Putting one back in that can hold the weight and looks correct is my concern. Thickness used for the new board?
- Paint. I'm going to be doing this in my garage. Last cabinet work i did was all black, and Satin Black spray paint worked great for spot repairs. That's not going to work here. The decals don't reach the edges, so i need to have a good color match for paint. I've read that some have used a roller for application, but I don't think it will have the finish I'm after. Since I am not doing this all the time, I don't want to spend a fortune on a paint gun. Any suggestions on other options or a model (that is reasonably priced)?
Vid has excellent postings for playfield restoration, so I am hoping this might spark the next discussion.
