Hello once again!
So.... I'm restoring my Theatre of Magic....what have I got myself into! It's been going well so far and I've successfully stripped the topside and now moving onto the underside, Is it better to label and photo each wire and de-solder them from their respective terminals then remove from the playfield or is it better to label and remove each lamp socket/coil/terminal unit etc and leave it attached to the loom? The playfield is being being restored by someone else so I may not have it back for a year so unfortunetly it isn't a case of just swapping each piece onto a new field and resolder immediately. Thanks in advance for your replies.
