The twist style head lock appears a simple and elegant mechanism, with its hex wrench companion. Tonight, after some simple maintenance on my JP, the lock will not rotate, except for a very little bit. Suggestions?
20210217_235956 (resized).jpgCan you post a pic looking down into it from above?
Is the box square or have the side been pinched in a bit? It's softish sheet metal.
RussM
The indentation visible on the front (and correspondingly on the back) creates a bump on the interior which provides the ratchetting feel/function for the lock.
My next step is to go ahead and pry it apart a bit to see if those ridges are causing the binding.
Have you tried lightly pulling or pushing the backbox while attempting to rotate the lock? I could swear i ran into this same problem on a friend's DE game recently and that was the trick.
Good luck!
This page was printed from https://pinside.com/pinball/forum/topic/de-head-twist-lock-jammed and we tried optimising it for printing. Some page elements may have been deliberately hidden.
