Fixing a friends BTTF. Flipper coils are correct but the ball goes all over the place with bounces. What is the next coil down for a DE pin? Anyone do this with good results. Thx
What kind of rubber do you have in the machine. Not just flipper rubber. I had super bands posts in mine. After replacing those, the ball doesn't jump any more.
Quoted from CactusJack:Less ohms means more power. Higher ohms means less power.
Thx cactus. I'm too adhd to understand that chart. I need a coil number from pinball life
Quoted from billsfanmd:Russ if wanted to reduce power buy like 10 percent what coil would you try ? Thx
What flipper coils are in your game now?
RM
OK, 23-900 means 23 gauge wire and 900 turns of that wire in the coil
23-900 (090-5020-30) is 4.05 Ohms resistance, so you will want a higher-ohm coil (less power)
23-1100 (23 gauge wire and 1100 turns) 090-5030 is 5.1 Ohms so how about giving those a try?
Make sure you get the ones with diodes and make sure the right wires are on the right lugs.
RM
thanks russ...will do. I'm pretty sure wires are correct....is there a pic of correct wires? I just copied what was on there before.
Always mark wires before removing them: e.g. "BAND" "NO BAND" (i.e. banded end of diode vs unbanded end) or whatever works for you because getting it wrong can blow the transistor or the diode or both (Fun to fix! not.)
RM
This page was printed from https://pinside.com/pinball/forum/topic/de-flippers-too-strong and we tried optimising it for printing. Some page elements may have been deliberately hidden.
