New! Dark mode!
(Topic ID: 115038)
D&D several solenoids out.
By atariaction
5 years ago
  • 10 posts
  • 3 Pinsiders participating
  • Latest reply 5 years ago by atariaction
#1 5 years ago
Just picked up a D&D. Several coils are not working. Checked/replaced all bad fuses. Says control board must flash 9 times to be working properly but it only flashes 6 or 7 times. Not sure. Was hard to tell. See pic of test sequence. So that is where I'm at. Any help or suggestions would be greatly appreciated. Thanks!
#2 5 years ago
nothing? is this game to obscure?
#3 5 years ago
What do you mean that they aren't working? Are they not firing at all or are the wrong ones firing?
You do need 9 flashes so it is important to figure out how many you are getting.
#4 5 years ago
3 aren't firing. the 2 lock mechs and the drop target reset. will have to check number of flashes. machine at my neighbors (i ran out of room
#5 5 years ago
OK just ran some tests. The suspect coils do NOT fire in solenoid test. The co-responding switches are working in switch test from what I was able to test. The suspect coils are all getting almost no voltage and the working coils are getting about 45 volts.
Non-working coils read as follows
Drops 17 J06-05
Lair LT 18 J09-01
Lair RT 19 J09-02
Teleport left 20 J09-03
Teleport right 21 J09-04 this one is intermittent
Top bumper 11 J06-01
Left bumper 12 J06-02
Right bumper 13 J06-03
Bottom bumper 14 J06-04 this bumper actually works fine but it is on the same connector it seems so I thought that was strange?
I reseated connectors J6 and J9 on the board but that did nothing. So do you think this is likely a transistor(s) problem?
Also I'm sure I was reading the LED sequence on the wrong board. The LED sequence on the other board is perfect and correct.
#6 5 years ago
probably a failed transistor from what you say. check the corresponding Qx, and associated diodes.
might want to check if a wire isnt cut somewhere, like the common wire for these coils, sounds like too many coils failing to me.
#7 5 years ago
Well the culprit was found. wire off the daisy chain! all solenoids now working!
#8 5 years ago
archaik you were right
#9 5 years ago
see, told you ^^
now you can go kill the dragon
#10 5 years ago
Hells Yea!!!!!!
2,800 (OBO)
Austin, TX
$ 137.00
Green Bay, WI
$ 19.00
1,800 (OBO)
Port St. Lucie, FL
Waltham, MA
$ 39.99
Lee's Parts
$ 75.00
$ 125.00
pinballmod
$ 59.99
Hardware
Chroma Pinball
PinBoss Mods
$ 7,699.00
Classic Game Rooms
$ 22.00
Filament Printing
Cobra Amusements
$ 14.95
$ 68.50
Sparky Pinball
