(Topic ID: 264375)
Data east DMD fuse blowing
By monkfe
  • 18 posts
  • 6 Pinsiders participating
  • Latest reply 4 years ago by Roverius
#1 4 years ago
I recently replaced the caps on my Tommy power supply board, after reinstalling the board, my Power supply fuse for the DMD is blowing. I removed the power cable to the DMD, and I have all my power supplies on the board, plug in the DMD, fuse blows?....sort of coincidental that the DMD would just blow, I did find a bad transistor in the high voltage area of the board. Is this common for a DMD failure to blow the fuse ie shorting out? Thanks Gents.
#2 4 years ago
Solder bridge somewhere or capacitor in backwards perhaps. I'd go over your work again carefully.
#3 4 years ago
yeah checked the polarity again....all good, I'm getting the correct voltages at the connector without the dmd plugged in...? so weird.
#4 4 years ago
Check the transistors and diodes of the high voltage section.
#5 4 years ago
Yeah did that...one was bad, I wonder if it did something to the display....diodes all good too
#6 4 years ago
if you are only blowing the fuse when you plug in the dmd. the short has to be in the dmd or on the cable to the dmd.check and make sure no connectors on the dmd are touching something they shouldnt be.
#7 4 years ago
Quoted from jgadzia:
Yeah that's what I thought too, maybe a screw dropped I to it, but all good.
#8 4 years ago
The DMD is probably shorted and needs to be replaced. You can find another plama DMD in the market section for cheap or upgrade to LED.
#9 4 years ago
any way to specifically test the dmd? for a short ( no pun) of replacing it with another? I'll probably just do a color dmd.
#10 4 years ago
The problem is not nessesarily with the display.
Removing the connector from the display just opens the circuit of the high voltage.
The fuse is connected to the center tap of the HV section and is in fact a return fuse.
Anything in the HV-section can cause the short.
A bad transistor can cause the short.
Do you have the oppertunity to test the DMD in another game?
Then you will know for sure.
I think the problem is your HV-section on the power supply board.
#11 4 years ago
Quoted from Inkochnito:
Hmmm would it work in my William's game...just enough to fire it up?...I'd have to check the connector pin out
#12 4 years ago
I've seen shorted DMDs before. Before you install the DMD in another game I would urge you to do a short circuit test on all pins against ground. With the DMD removed from the game, take a multimeter and put it in ohms mode. Take your black probe and touch one of the the metal screw contacts on the DMD for your ground connection. The take the red probe and touch each high voltage power supply pin on the DMD. You should only get a beep/zero ohms/OL on the meter when touching the red probe on the ground pins (only pins 4 and 5). If this happens when touching any of the other pins, the DMD is shorted.
Pin 1: -125 volts
Pin 2: -113 volts
Pin 3: Key
Pin 4: Ground
Pin 5: Ground
Pin 6: +5 volts
Pin 7: +12 volts
Pin 8: +62 volts
#13 4 years ago
Quoted from Crash:
I've seen shorted DMDs before. Before you install the DMD in another game I would urge you to do a short citcuit test on all pins against ground. With the DMD removed from the game, take a multimeter and put it in ohms mode. Take your black probe and touch one of the the metal screw contacts on the DMD for your ground connection. The take the red probe and touch each high voltage power supply pin on the DMD. You should only get a beep/zero ohms/OL on the meter when touching the red probe on the ground pins (only pins 4 and 5). If this happens when touching any of the other pins, the DMD is shorted.
Pin 1: -125 volts
Pin 2: -113 volts
Pin 3: Key
Pin 4: Ground
Pin 5: Ground
Pin 6: +5 volts
Pin 7: +12 volts
Pin 8: +62 volts
I'll check it out tomorrow!
#14 4 years ago
Quoted from Crash:
Pin 1: -125 volts
Pin 2: -113 volts
Pin 3: Key
Pin 4: Ground
Pin 5: Ground
Pin 6: +5 volts
Pin 7: +12 volts
Pin 8: +62 volts
VCC, which is pin 6, 25 ohms, everything else off scale (meter set at lowest range), so I'm going to guess that its not shorting out? ...
#15 4 years ago
So my color dmd came today, installed it, it powers up(able to see menu ect), but now my cpu won't boot. PIA is on steady (no blinking), but my blanking led never comes on...5v on as well. Book says 6821 may be bad, replaced all of them (rottendog board mind you). and still no difference....thoughts gents.
#16 4 years ago
I've read ColorDMDs may draw more power from the game's 5v supply. Have you checked the 5v test point at the power supply board with the ColorDMD connected?
#17 4 years ago
yes...normal voltage a solid 5v. Need some info on the blanking circuit...Does the 555 make a steady output for this? Is this something that I should be able to see with a logic probe?
#18 4 years ago
Maybe a suggestion:
On my Data East, there was a humming comming from the speakers. This is a common issue on the D/E machines.
So, i have used a PC powersupply and removed all the unneeded power cables from it. I just kept the 12V 5V -12V and GROUND.
The humming is gone and i don't have problems anyhow.
So, maybe, you can use the 5V also of a PC powersupply. I know, it is not genuine, but it might solve the power issue.
Or, maybe you've found a solution allready and the DMD is allready working.
Filament Printing
€ 25.00
Pin-Decals
€ 27.50
Pin-Decals
$ 45.00
$ 18.50
Playfield - Plastics
5,100
TheDudeMods
$ 54.99
$ 5.00
TheDudeMods
$ 18.95
4,300
Fairfax, VA
$ 16.95
Mitchell Lighting
$ 28.00
$ 18.95
This page was printed from https://pinside.com/pinball/forum/topic/date-east-dmd-fuse-blowing and we tried optimising it for printing. Some page elements may have been deliberately hidden.
