(Topic ID: 72482)
Data East Star Wars Club...Members & Fans Welcome.
By MustangPaul
7 years ago
  • 3,945 posts
  • 338 Pinsiders participating
  • Latest reply 3 minutes ago by thechakapakuni
  • Topic is favorited by 163 Pinsiders
There have been 1,158 images uploaded to this topic. (View topic image gallery).
There are 3945 posts in this topic. You are on page 78 of 79.
#3851 29 days ago
Quoted from Pahuffman:
I have as well and didn't have any issues. And yes everything looked fine on the original high voltage DMD until I made the swap. Could it be a ribbon cable or something? I highly doubt it's just a Data East swap issue since the DMDs do essentially the same thing on all games.
Since the original worked fine, I would look more at the Stern one having a fault. Was the LED display known to be working perfectly?
#3852 28 days ago
Quoted from Kawydud:
Yes it was working fine in STTNG. I did find another thread with a similar issue, but it was never resolved.
#3853 20 days ago
Hey guys, I’m changing out the led’s to normal bulbs and have a question. What bulb size do I use for like under the slingshots, the lane guides? I’m sure all the leds are #44 that were in the game when I bought it. Where do you use the #47 bulbs. I can’t find an actual placement guide of which sizes go where.
#3854 20 days ago
Quoted from Enki:
a #47 is just a dimmer #44. I'd just use #44 (bayonet) and #555 (wedge).
#3855 18 days ago
Quoted from cabuford:
Or, #47 is less stress on the GI circuitry, because, the lamp filament draws less current
than the #555 and #44 lamps. A substitute for #555 lamp is a #259 lamp.
#3856 15 days ago
Left the club ! Great game, I enjoyed it back in the day and I enjoyed restoring this one but that old enemy ...space ....forced sale .......
May the force be with you SW owners
#3857 15 days ago
Quoted from Ive:
Left the club !
"No one's ever really gone..."
#3858 15 days ago
Finally some spare time to install new plastics, note the lexan protection over this commonly broken piece.
#3859 15 days ago
Slings getting done. May have to adjust lighting, CPR plastics dont let as much light through.
#3860 15 days ago
Quoted from gdonovan:
Hey I just picked up one of those Hot Wheels Millennium Falcons. How did you mount it?
#3861 15 days ago
Quoted from thechakapakuni:
Drill two holes in bottom and ran tie wrap through body
#3862 15 days ago
Everything replaced today.
#3863 13 days ago
I have a set of plastics sitting around that I bought awhile back. I needed just a couple so I still have the majority of the bag. I used the slingshots, boba fett and maybe one or 2 more. The rest are here and just sitting. If there's a specific plastic you are looking for PM me and I'll see if I have it and hopefully we can work out a deal to get it to you rather than you buying a whole set for just one or 2...like I did
#3864 13 days ago
Star Wars finally makes it into the line up. All I need to do now is hide an Ewok in there for the Mrs. and wait for my color display to arrive.
Gary
#3865 13 days ago
Tweaking the lighting for the game room. Replaced the retro warm white in the slings for 5050 sunlight white and added a spots on the left sling and right in front of Jabba's cave on right.
#3866 13 days ago
Pulled the trigger on an LED ColorDMD today. Looking forward to the upgrade!
#3867 13 days ago
Best upgrade we made to ours!
-Paul
#3868 13 days ago
Agreed. Totally worth it.
#3869 12 days ago
Hello everyone. Finally joined the club!
I picked up a fairly routed one.
Its been sitting for about 5 years in the warehouse. It does have some LEDs but they're all coming out and getting replaced
It has a bill acceptor in the door and its gonna need some love but the PF is almost perfect.
It even had the original manual and keys inside.
Any suggestions on where to start beside the obvious? Titan rubbers, leds, etc.
20210218_211041 (resized).jpg20210218_211058 (resized).jpg20210218_215845 (resized).jpg
#3870 12 days ago
Welcome. Doesn’t look too bad. I guess it really depends on how far you want to go. I generally take it down the the PF, replace plastics, leds, clean parts. So really depends on how much time you want to spend. I replace the balls, clean the PF, and upgrade to ChadHs 1.07 ROM at a minimum
#3871 12 days ago
"Any suggestions on where to start beside the obvious?"
Do the R2D2 and death star motors work?
Obviously check all the switches.
#3872 12 days ago
Also get some Cliffys for them scoops
#3873 12 days ago
Yes they work really well.
Already on order
Do i have to burn my own ROM? I was hoping to just buy one like I did for my TAF
#3874 12 days ago
Quoted from Dthwsh:
https://mattsbasementarcade.com/
He can burn you the latest.
#3875 12 days ago
Whenever I get a new pin I just play it for a few days just to take note of anything that's not working properly, or doesn't look good, and I make a list of things it needs, or upgrades I want to do. I'll keep playing it while I'm waiting for whatever parts I ordered off the list I made.
When parts arrive I tear the top side of the playfield down for a deep cleaning (leia's beard), polishing and waxing. While it's apart I get familiarized with everything (mechs, switches, ramps, plastics...etc), and clean each part I took off before I reinstall it. When everything's spic-n-span is when I install new bulbs, rubbers, and piece everything back together. This is also when I'd remove all of the lamp boards, and reflow solder on the connections.
I also install a lithium battery board in place of the AA's (or NVRam). Check all the fuses to make sure they're the right value, and that the holders are still in good shape. Check the boards for corrosion, and old bulging caps that may need to be changed.
I believe it was a fellow pinsider Mof that posted a really detailed checklist he goes through for each pin he works on. It's a very thorough list that covers everyting.
I guess it's all dependent upon what you're really looking for.
Congrats, and enjoy!
-Paul
#3876 11 days ago
Quoted from Jackaltr:
I got the side blades from ministryofpinball.com. They’re the only ones I found that really matched the art and theme.
[quoted image][quoted image]
Thinking about these or chrome/mirrored. A title that begs for them frankly!
#3877 10 days ago
After procrastinating for a long time, in a home not so far away... I've finally got my Pinsound mix ready to be shared with the masses. Thanks to Nicolas at Pinsound in getting the file format updated for the new format as this was made back in the initial months when Pinsound was new. I've had a few people test this over the years; but, haven't placed it online until now.
It has everything, minus the Data East pinball specific callouts reworked and replaced with source materials. Even the pre-multiball DMD sequence has been re-orchestrated using the sound sequence from Episode VI's Death Star super laser firing. I've discovered that the timing for DE games isn't 100% consistent so, the version included in my mix is the best compromise from the testing on the peoples machines over the years.
The mix is very, very large in size and a lot of the cues have multiple variations present in the folder so the game will play them randomly. Due to the size, you need to make sure you use a very fast USB flash drive with excellent read speeds to keep from having any audio delays.
Included in the download is a custom boot.wav file you can use to give the game the proper fanfare it deserves when you power it up.
Enjoy everyone.
https://www.pinsound-community.org/forum/index.php?/files/file/346-swde-original-trilogy-ultimate-orchestration/
*The download is pending approval from Pinsound; but, should be available shortly.
*Please excuse the horrible video quality and play while I was recording this.
#3878 10 days ago
Nice Jedi! Can’t wait to give it a spin!
#3879 10 days ago
Quoted from jedimastermatt:
Enjoy everyone.
Looks like the link isn’t working, so I’m guessing waiting on approval?
#3880 10 days ago
Yes. Just checked it and it's still pending.
I've got two more orchestrations uploading (Shadow and STTNG) and see it still pending.
#3881 10 days ago
Looking forward to that mix!! It’s perfect!
#3882 10 days ago
Enjoy everyone.
this is absolutely the best pin sound I have tried, you took great time to accomplish this, I enjoy playing my pin with your files. Thank you for letting me try ahead of time.
#3883 10 days ago
If you want to take it even further, get the PinSound Shaker as well. There's a shaker configuration for SWDE available (or I can send it to you). The haptic feedback from the shaker takes your machine to yet another level.
#3884 8 days ago
Just picked up a DE Star Wars...one question, is the death star supposed to rotate the entire time you are playing? Mine seems to rotate sometimes but not always.
thanks
#3885 8 days ago
Quoted from dino7c:
thanks
The two animation motors are tied to each other...
If R2D2 head stops then the DeathStar model should also stop.
#3886 8 days ago
Quoted from dino7c:
thanks
Check the relay under playfield, broken solder joints common. As long as the ball is in play it will rotate one way and then the other.
#3887 8 days ago
I have a question about nvram.
I just installed it into 5D on the cpu board which is version is 03 and J4 is not there but J5 is. When I take the batteries out everything resets, tells me to open the door. I change the settings back to free play turn off and back on but still says to open door and it’s all reset again. What am I doing wrong?
#3888 8 days ago
I have 2 R2 kits boxed up and ready to ship. Anyone interested PM me. 100.00 shipped in US only. I won’t be making anymore. I will also be uploading the files and post a link. The kit comes with legs, body, dome, screws, lights ect. You just need to finish like a model. Modify mounting brackets and install stock lighting if you want
023E3CC7-9CDB-447F-844D-0F63A8641F66 (resized).jpeg29BD6417-63B1-4142-9686-554DF0979FA3 (resized).jpeg4CE54F1D-AAD9-464B-BAD8-D40FC84AF121 (resized).jpeg
#3889 8 days ago
Enjoy everyone.
It looks like the file is approved and is now available. Enjoy!
#3890 8 days ago
Quoted from vec-tor:
thanks, tested some more and yes both R2D2 and Death Star rotate sometimes but not often and stop randomly
#3891 8 days ago
thanks, looking now...anywhere specific that is most common with this issue?
#3892 8 days ago
Quoted from dino7c:
Broken solder joints on the relay connector pins
#3893 8 days ago
Nice! Gonna give it a run this weekend
#3894 8 days ago
Thanks, checked the relay pins and everything looks good. They will both work for 30 seconds or so, stop, randomly start working again. Bad motor? would that have them both stopping at the same time.
#3895 7 days ago
I have a question for the group.
I have cleaned and waxed the PF and I've played a few games now.
The Game was a routed machine and probably sat the last 5-8 years.
Anyway, the pop bumpers sound really chincy, like really cheap. Compared to my Addams that sound solid when a ball hits them.
I checked under the playfield, everything is tight.
So my question is has anyone used williams pops on this machine? OR do you know a way to firm up the pops?
thanks.
#3896 7 days ago
Quoted from Enki:
I was never able to get my NVRAM installed properly and had similar issues so im following this also
#3897 7 days ago
Quoted from Dthwsh:
thanks.
Data East games of this generation had "chunky" sounding pops. It's just part of the feel of game. I'm sure some of the feeling is from the big caps that are on it.
I don't know if I would change it or if it could be done.
#3898 7 days ago
Star Wars and Checkpoint have unique pop bumper caps that move up and down with the pop rings, the only two pins that ever came that way. The extra mass makes them slower to actuate.
#3899 7 days ago
Quoted from DJY2J:
Been my experience that DE pins are very easy to install NVRAM. The only problem I had with one was a Time Machine that required me to leave the batteries in during the swap and was fine after that. once the setting were set I removed the batteries and all was good.
#3900 7 days ago
One of the caps has a standard top on it and it has a tighter feel. Maybe I'll swap them out and see how it is....
Professor Pinball
$ 9.99
4,100 (OBO)
Sale Pending!
Elkhart, IN
$ 39.50
Pixels Arcade Games
$ 14.95
