(Topic ID: 72482)
Data East Star Wars Club...Members & Fans Welcome.
By MustangPaul
7 years ago
  • 3,834 posts
  • 333 Pinsiders participating
  • Latest reply 53 minutes ago by ChadH
  • Topic is favorited by 159 Pinsiders
There have been 1,126 images uploaded to this topic. (View topic image gallery).
There are 3834 posts in this topic. You are on page 57 of 77.
#2801 2 years ago
And it begins...cleaning up the new purchase! First step is power conversion to 110!
1791AD2D-0EC4-4C92-B9A6-13DE44401B01 (resized).jpeg6C2DB1E5-F606-4375-89F6-09735F73AB6F (resized).jpeg6C477CD1-231C-4E90-B267-67821EEDA38A (resized).jpeg
#2802 2 years ago
Quoted from Guido13:
Have fun... Congratulations!
#2803 2 years ago
I've had my DESW for 21+ years. We still love it. Pairs well with our Stern SW as well. Good luck with the restoration!
#2804 2 years ago
Spent last night tweaking, swapped my color dmd over from avatar le. Had to make a custom power cable harness, but worked like a charm. Is there any way to disable the multiball gi flash? One of the things I just hate about DE games of the era.
#2805 2 years ago
Quoted from dung:
Hard wire the circuit. Or, reprogram the ROM.
#2806 2 years ago
Quoted from dung:
I have an EnerGI Maestro in both of my Data East pins. You can control the intensity and fade rate of the GI. You could set it to always on but I found that giving it a slower fade rate makes it less crazy especially if you have LEDs. It also bypasses the relay so you don’t hear the clicking anymore.
#2807 2 years ago
are these nails supposed to be sticking out under the slingshots on both sides. looks like someone just hammered these in for some kind of support. If they are not supposed to be there is there any reason to leave them. i am going to clear coat this baby.
#2808 2 years ago
Quoted from cabuford:
Hrm, would probably sell before I did that. I do like the game, but plan is to sell down to 10ish machines this year for maintenance purposes. Interesting idea though and will look into it.
#2809 2 years ago
Quoted from jgadzia:
The nails keep the top plastics from sagging on to the kicker heads. If you remove them...
Make sure to put them back and that the top of the nail head sticks just above the kick heads.
The kickers will jam on the underside of the sling shot plastics.( just look at old Gottlieb EM games).
I think about/approximately 1/8" above the kicker head or more.
#2810 2 years ago
Playing the new purchase tonight, and in the middle of a game, this piece comes flying out. I looked everywhere for where it came from. Any ideas?
#2811 2 years ago
Top right corner plastic just under chewy.
#2812 2 years ago
Two questions:
1. Do these drop targets look right? Especially the yellow one?
2. I’m having issues with the general illumination lights. Currently, the front half of the machine is lit. The back half is not. Interestingly, it was the opposite yesterday. Ha!!! I did reset some of the wiring cables and connected a few ground wires.
Any ideas would be helpful!!!
#2813 2 years ago
Two questions:
1. While the yellow is very unique and looks like a krakhead spent quality time installing it, they sell full drop target kits & decals at Marcos
2. I believe it’s the CN8 connector on the Power Suppy. If it’s brittle or cracked from the long term heat, then you might need to wiggle it or replace it
Good luck
#2814 2 years ago
Quoted from wolfemaaan:
The other option here is loose fuses. I believe the front and back halves of the GI run on separate fuses.
#2815 2 years ago
To test the fuses just go push on them. The holders they use fail over time and no longer grip the fuse with enough tension causing it to not conduct.
#2816 2 years ago
Yes! bad cheap fuse clips!
Yes! bad cheap connectors... Power Supply & PPB board!
#2817 2 years ago
Who makes the best repro DE SW translite? I got one off Ebay and its total crap.
#2818 2 years ago
Has lines running through it.
#2819 2 years ago
#2820 2 years ago
Quoted from PACMAN:
nd its total crap.
Who was the seller? I'm looking as well, and would like to avoid...
#2821 2 years ago
Prestige 1
#2822 2 years ago
Quoted from PACMAN:
[quoted image][quoted image]
He won't take it back?
#2823 2 years ago
One step forward....two steps back! Thanks for all the help. You guys are awesome. I wanted to learn more about pinball machines and here it is!
The original power supply board - front half of GI lamps worked. Back half did not. The lamp matrix/cpu controlled lamps worked but I noticed a few lamps quit working the more I messed with it.
The second power supply board (friend had a spare) - all GI lamps worked. No lamp matrix/CPU controlled lamps worked AND the F2 fuse burnt up above the capacitor and F4 fuse burnt up on the power supply.
I reinstalled the original power supply board - ALL GI lamps work. No lamp matrix/cpu controlled lamps work AND the F2 fuse burnt up and the F4 fuse burnt up!!! WTH?????
The flashers, coils, DMD all worked with both power supply boards.
New power supply board? MBU issue? Other thoughts?
On another topic, I have a spare MBU (Rottendog) but the DMD won’t fire up and I can’t oberate the game. I have a CPU 1.02. I’m thinking this chip is not compatable with the new MBU?
Thanks for the help!!!!!
#2824 2 years ago
When you say the F2 & F4 fuses “burnt up” do you mean they keep blowing out?
#2825 2 years ago
Correct. The fuses keep blowing out.
#2826 2 years ago
Double check your connections, sounds like you may have connectors on the wrong headers or off by a pin or maybe upside down? Not all of them are keyed if I remember correctly.
#2827 2 years ago
Yeah he’ll take it back.
Quoted from MustangPaul:
#2828 2 years ago
Quoted from PACMAN:
Good. I really don't understand how sellers can let that kind of shit out, I test the mods I sell 4 times as I make them and 1 final time before they are shipped. I have had ZERO returns for any kind of problems.
#2829 2 years ago
Quoted from dung:
Just got a star wars. Working on updating to the home rom as we speak. Had a question on the display rom. Currently running A1.05. What version do I need for colordmd and chadh's rom? His site says its the same as colordmd, but colordmd doesn't say which one on their site.
Display 1.05 is what you need. I have chads rom and a color dmd and it works great.
Display 1.04 and 1.05 are actually the same code...but 1.04 is the 2x 2MB chip version and 1.05 is the 1x 4MB chip version combined on 1 chip.
Depends on which way the DMD board is jumpered to read.
And congrats on the new machine!
#2830 2 years ago
What slope do you like best for the play field? 6? 7? Somewhere in between?
#2831 2 years ago
I set all my games to 6.5 and it seems to work just fine.
#2832 1 year ago
Hi,guys I bought a DE SW,The R2D2 is yellow and very aged.Is someone here that makes a restoration,re chrome.??
#2833 1 year ago
Quoted from robertg130:
I was wondering the same thing.
#2834 1 year ago
Chris at pinballplating.com can get plastic rechromed. He's sc93cobra here on Pinside.
#2835 1 year ago
Keep in mind - R2D2 is NOT chrome in the films. His head dome or whatever you call it is really more of a satin aluminum finish. I haven't done it myself but have seen people have success with simply spray painting the part with a satin silver rattle can. Its much more authentic in my opinion.
#2836 1 year ago
Quoted from Dkjimbo:
True but it came chromed on the game. Which ever he prefers.
#2837 1 year ago
Technically R2D2 had a little man inside as well, not sure if anybody has tried to replicate this as well inside the game. ‍♂️
#2838 1 year ago
Has anyone tried rechroming R2? He’s pretty fragile.
#2839 1 year ago
Quoted from PACMAN:
When I had the game I had it re-chromed and it turned out perfect....also about $60. Like I said Chris at pinballplating.com will take care of you.
#2840 1 year ago
I streamed DESW last night for about 3 hours. Video should be up for about 13 more days.
https://www.twitch.tv/videos/371031062
#2841 1 year ago
Snubbed again! Ordered another SW translite off Ebay from Classic Arcades.
Looks good right? Or, does it?
IMG_6659 (resized).jpgIMG_6660 (resized).jpgScreen Shot 2019-01-29 at 2.30.42 PM (resized).png
#2842 1 year ago
WHAT??? Did they put the Remove sticker on the wrong side??? This is beyond stupid. I gotta hear what they have to say about this.
#2843 1 year ago
It’s printed BACKWARDS. The film is on the correct side but the image is flipped.
#2844 1 year ago
I got this but pretty sure Pac-Man isn’t laughing. What’s that saying? “Fool me once, shame on you; fool me twice, shame on me.” Better you than me? ‍♂️
#2845 1 year ago
I sent pix and requested a return through EBay. EBay provided an automatic return label. I printed it out, then mailed it. Then I get this message from Jeff at Classic Arcade.
New message from: classicarcades (20,788YellowShooting Star)
“I would have sent you another translite at my expense and you could keep the defective one but you did not give me a chance. You forced me to send a return label and refund and I did not need the backwards one back and have no choice but to just refund the purchase and pay to return the translite”
#2846 1 year ago
Quoted from PACMAN:
That's a shame, I'd love to have the backwards one as joke wall art. How did it look otherwise? Why didn't you just reach out to classic arcades first and point out the super obvious mistake?
#2847 1 year ago
It just looked “ok” nothing special. Brown details were washed out with solid black blotches. I think all the repro guys are using the same crappy scan. I’ll show you a comparison when I get back to my Mac.
#2848 1 year ago
Original (not a great photo) compared to repro.
Screen Shot 2019-01-30 at 12.15.48 PM (resized).pngScreen Shot 2019-01-30 at 12.22.05 PM (resized).png
#2849 1 year ago
Look at Chewys hair, Bens cloak and Princess' skirt. The details are gone! Just blacked out blotches.
This is the scan thats floating around out there that all the repro places are printing. Its either a bad scan or lazy restoration work or both.
#2850 1 year ago
Thanks for the comparisons. I noticed similar issues with my repro plastics. Luckily my backglass only has a few minor scratches so I don't need a new one unless I get OCD on it.
That backwards one was funny though, how do you not notice that while you're making or shipping it?
$ 99.00
Arcade Upkeep
$ 9.99
$ 28.00
