Hello pinball technophiles! I have an issue with the chase lights on my DEST. As soon as I turn on the machine the first set of lights comes on immediately. The other two sets (there are 3 on each side) flash in sequence and speed up/slow down as they're supposed to.The first set is powered through the orange and brown wire. The other 2 are orange/red and orange/black. The leads from the CPU come from CN3 and are blue/red, blue/orange and blue/brown.
I've replaced the chase light PCB with a new one from Marco. The chase light ropes all work. I tested the TIPs on the PCB and I also did a continuity test throughout the whole wire harness that supplies the chase lights. I spoke with a technician from Stern who said it might be a bad PIA at location 11B. However, when I start the machine, the row of LEDs on the CPU lights in the proper sequence, indicating all the PIAs are in working order. This same system is used on Hook.
If anyone knows or has a clue as to what might be the problem I'd be most grateful to learn about it. Thank you to all who offer help.
