(Topic ID: 57401)
Data East Star Trek blowing f5 fuse on ppb board
By klinde1
10 years ago
  • 5 posts
  • 2 Pinsiders participating
  • Latest reply 10 years ago by klinde1
#1 10 years ago
My Data East Star Trek is blowing my f5 fuse . I have narrowed it down to vuk causing the issue. If I disconnect power to the vuk the fuse does not blow and everything else seems to work fine.I measured the voltage at the purple-yellow wire that powers the vuk I get 72 volts. All other coils seem to have a more normal voltage of 39.If I power up the game with the vuk coil connected it blows the fuse right away.
#2 10 years ago
Coil may be bad and in need of replacing. Does the plunger move freely in the coil? Measure the coil's resistance, shouldn't be under 2 ohms. Driver transistor(s) are probably shorted, as well as the coil diode if it has one.
Rob Anthony
Pinball Classics
http://LockWhenLit.com
Quality Board Work - In Home Service
borygard at gmail dot com
#3 10 years ago
The coil moves freely I also replaced it with a known good coil. Probably shorted transistor I am getting 72 volts on the purple -yellow wire and it is not attached to the coil. Would the transistor be on the cpu board or the ppb board and how can I check it.
Kirk
#4 10 years ago
Diode on the coil? Properly wired if so? Purple/yellow wire to cathode(banded side of diode)?
Transistor will probably be on th PPB (TIP36) and the CPU(TIP102). Check the manual for transistor designations.
Rob Anthony
Pinball Classics
#5 10 years ago
Purple -Yellow wire is to banded side of diode on coil. All three legs of Q3 on the ppb go direct to ground looks to be shorted to me.
$ 115.00
$ 100.00
$ 18.95
3,400
Sanford, NC
$ 65.00
$ 18.95
$ 5.00
$ 18.95
$ 190.00
Lighting
$ 27.95
Professor Pinball
Hardware
Filament Printing
$ 11.00
RGP Models
This page was printed from https://pinside.com/pinball/forum/topic/data-east-star-trek-blowing-f5-fuse-on-ppb-board and we tried optimising it for printing. Some page elements may have been deliberately hidden.
