(Topic ID: 255398)
Data East Speaker problem
By jgadzia
  • 3 posts
  • 2 Pinsiders participating
  • Latest reply 4 years ago by jgadzia
    #1 4 years ago
    OK i have a data east star wars that i changed the main cabinet speaker to a woofer with no problem. The data east boards have a neg and positive lead off the sound board for each of the 3 speakers(in cabinet, Left and Right front speakers). Now i wanted to be able to kick up the woofer without blasting the main left and right speakers so i added an (LPAD 50w 8ohm). I didnt want to have to add an LPAD for both the left and right speaker so i took and wired them both to the LPAD. The issue is that it works but just barely (it may diminish the volume by 10% at most, otherwise you can barely tell that the LPAD is doing anything. I am sure this has to do with the fact that i am hooking 2 outputs to the same LPAD, but i am not sure what the fix is. Do i need to purchase a different LPAD, and if so which specs do i need to get?
    #2 4 years ago
    Sounds like you are using a mono LPAD. You should use a stereo LPAD - which is just two mono LPADs ganged together, using one rotating shaft to control both channels equally.
    #3 4 years ago
    awesome, i think that is what i need.
    thanks so much
    This page was printed from https://pinside.com/pinball/forum/topic/data-east-speaker-problem and we tried optimising it for printing. Some page elements may have been deliberately hidden.
