(Topic ID: 90010)
Data East PPB board fix/repin
By joekiss
6 years ago
  • 12 posts
  • 3 Pinsiders participating
  • Latest reply 6 years ago by dothedoo
There have been 8 images uploaded to this topic. (View topic image gallery).
#1 6 years ago
Photos are of a board from a LW3 game. The burned part is for the connector for the PF lights. I repinned it still didn't work. I put the board in a TFTC game to check still no PF lights. Did I pin it wrong or is something else wrong with the board??P5060269.JPGP5060270.JPGP5060271.JPGP5060272.JPG
#2 6 years ago
Just traces and fuses, right...no other components involved? Did you verify continuity from each pin to the end of its corresponding trace?
#3 6 years ago
Also, with all that carbonization, make sure there's no shorts between the pins.
#4 6 years ago
Looking at the schematics, you should have continuity on the following pins:
IN 1, thru F4, OUT 5
IN 2, thru F3, OUT 6
IN 3, thru F2, OUT 7
IN 4, thru F1, OUT 8
I could have my In's and Out's reversed, but you get the idea.
#5 6 years ago
How do I verify continuity from the pins??Can I do that as is?
#6 6 years ago
Quoted from joekiss:
With a volt/ohm meter
Oh, I thought you already replaced the parts. Clean all the burned crap off and make sure all the traces are separated and solder on the new header, then test with the ohm meter.
#7 6 years ago
Doesn't look like there's anything left to solder on to. Looks like the through holes are gone and the traces on the solder side of the board burned away. Unless you're good at fixing through holes and burned traces, $130 for a new Rottendog DE PPB.
viperrwk
#8 6 years ago
Was wondering if I needed a new board.
#9 6 years ago
Yeah you'll have to solder directly to the traces and you'll want to be a little more delicate taking the connector on and off, but it can be done. This is a single sided board so there are no thru holes to worry about. I would give it a try. If it doesn't work....well, a connector is cheap, a new board isn't.
#10 6 years ago
Can you explain a little more?
#11 6 years ago
Scrape the solder mask off the ends of the traces (which you will probably do in the process of cleaning off the carbon anyway.) Then tin the ends with a little solder. Put in the header and bridge the solder from the header pin to the trace. You may have to use a short piece of wire if the gap between the pin and trace is too great. Just make sure that if you use pieces of wire you don't end up shorting any pins together.
#12 6 years ago
This isn't the best example, but you get the idea.
Buffalo, NY
Byron, GA
