Black Friday...perfect day to play some pinball.
Quoted from PinballManiac40:Because I seen this before,
Thanks,
So to you it appears to be a glitchy 5V circuit?
CN1 looks good.
And since you've put the fear in me........
I'm off to my local electronics store for new caps (yes, those stores still exist some places). The existing caps don't appear to have leaks, but they are almost 30 years old.
Quoted from DropTarget:Thanks,
CN1 looks good.
You often do not see the leak until you remove the original cap. Had the same thing with a JP recently. In addition to changing the 4 caps mentioned previously, check the fuse holders as they can break / crack. May be check the bridge rectifier too.
Have a look thru the DE JP thread as there has been lots of discussion on there.
Good luck
Skippy2904
Edit see you already did post on the other thread!
Quoted from Skippy2904:You often do not see the leak until you remove the original cap
Thanks,
I just got home with replacement caps and diodes, it appears that D1 is open. Bridge rectifiers are fine.
Fingers crossed.
Fingers crossed.
I never seen D1 open. You are using the diode test?
Thanks everyone.
I replaced C1, 2, 3 & 4 along with D1 which tested bad while in circuit (tested fine out of circuit). Now everything seems to be working as advertised again.
I did not see any evidence of a leaked cap, maybe after 29 years, one just kicked the bucket.
Thanks again. $5.00 in parts and a trip to the electronics store, which is always a blast.
Quoted from DropTarget:Thanks everyone.
Most are rated for a few 100 hours, amazing they last as long as they do.
Quoted from gdonovan:Most are rated for a few 100 hours, amazing they last as long as they do.
yeah, Pretty impressive
Merry Christmas! My Time Machine displays are not working on the backglass. Everything else seems to be fine.
What is the approach for trying to track down whether it is a loose wire or the display itself? Or anyone else go through this?
Thanks in advance.
Quoted from pinball2020:Merry Christmas! My Time Machine displays are not working on the backglass. Everything else seems to be fine.
Thanks in advance.
Start with taking voltage checks of displays.
Careful as they are high and will give you a good shock.
Curious if anybody local to new england has a spare DE MPU 520-5003-04. Some light corrosion would be fine, but my coil area is burnt to a crisp on one game and I would like to secure one that's a little cleaner before I put my R&B out on location again.
Quoted from radial_head:Curious if anybody local to new england has a spare DE MPU 520-5003-04. Some light corrosion would be fine, but my coil area is burnt to a crisp on one game and I would like to secure one that's a little cleaner before I put my R&B out on location again.
You don't need a -04. I think it came with a -03 but a -04 will work in the game. So, you should be able to use either one.
Thanks in advance.
Mine did this when I got it home also. On my machine, the ribbon cables were loose. Hope it's as easy a fix for you too!
Chris
Heads up on ROTTENDOG MPU004 - 3 for Data East games.
The PIA's used on the board, I have been trouble shooting, has some kind
of issue with addressing the DMD. W65C21N6TPG-14 lots ABC655.1 2123G029
are flawed.
I have switched around the PIA's to no avail.
I have tested continuity...etc on all components associated with CN22.
Finally, replaced U_9B with a MC6821 PIA and DMD works... displays player 1 fonts are now present.
Just passing this frustrating hair pulling info along.
Cheers.
Quoted from vec-tor:Heads up on ROTTENDOG MPU004 - 3 for Data East games.
are flawed.
Finally, replaced U_9B with a 8621 PIA and DMD works... displays player 1 fonts are now present.
Cheers.
Can you make this a little story like you see on www.pinwiki.com?
https://www.pinwiki.com/wiki/index.php/Data_East/Sega#Repair_Logs
Then I will add the text for future ref.
Always good to have this kind of info.
Quoted from Inkochnito:Can you make this a little story like you see on www.pinwiki.com?
Title:
DMD missing, one player game score fonts.
Data East Star Wars - (1.02) roms. with Rottendog MPU004 - 3 board.
Game plays fine, except during one player games the animated score fonts are missing.
With two player games, the player one score fonts would not show, til player two was up.
Isolated the problem down to a bad MPU004 - 3 board.
Tested continuity from CN22 to all associated components, etc.
Rotated all the PIA's W65C21N6TPG-14 and tested the MPU board, to no avail.
Resolution: Replaced U_9B W65C21N6TPG-14 with a MC6821 PIA. The DMD now works correctly.
are flawed.
Cheers.
Is that the new Western Design Center PIA chips? Those are supposed to be solid chips and have only heard good things about those. Haven't heard of any issues with those before? Did you identify just a bad batch of them? If so did you e-mail Rottendig support about it? I had heard they switched over to the Western Design Center chips specifically to improve quality. If you ran into a bad batch you should let them know about it.
If it is just the PIA for the display section then perhaps there is just something in that part of the circuit that doesn't play well with the Western Design Center PIA chips.
Quoted from Robotworkshop:Is that the new Western Design Center PIA chips? Those are supposed to be solid chips and have only heard good things about those. Haven't heard of any issues with those before? Did you identify just a bad batch of them? If so did you e-mail Rottendig support about it? I had heard they switched over to the Western Design Center chips specifically to improve quality. If you ran into a bad batch you should let them know about it.
curious too....
Keep in mind that this is a Rottendog MPU with the new Western Digital W65C21N6TPG-14 PIA. This is yet another example/reason I don't like repairing or owning Rottendog MPU boards, compatibility issues.
The Western Digital W65C21N6TPG-14 PIA work fine on the ORIGINAL MPU boards.
Quoted from PinballManiac40:Keep in mind that this is a Rottendog MPU with the new Western Digital W65C21N6TPG-14 PIA. This is yet another example/reason I don't like repairing or owning Rottendog MPU boards, compatibility issues.
Well it is too early to tell. The WDC chip may work perfectly fine in the Rottendog boards too. Could just be a bad batch of those chips. Until the root cause is determined it is just speculation.
Quoted from Robotworkshop:Could just be a bad batch of those chips.
That is what I'm thinking. The board might work correctly, if say it is in a Data East Simpson
type game.
I used 30 of the Western Digital PIA on various original MPU boards including old Bally Solid State MPU, without any issues.
Quoted from vec-tor:Title:
I've added the text to the http://pinwiki.com
Quoted from radial_head:RESOLVED: Lowering the value of R25 to 1k or 1.5k will allow you to bring the volume down to nothing.
Hey there DE/Sega heads. Looking for some confirmation making sure I'm reading this circuit right. I want to discuss the volume control section of the sound board circuit.
The volume input on the circuit seems to take -5V (from the output of VR1) and the pot controls the volume control on the TDA8199. From the way I understand it, the closer you get to ground (0) the louder it is, the closer you get to -5v, the quieter it is.
For a while now, I've just been adding a resistor in series with the volume pot wiring to make sure the volume pot can go ALL the way down, however there's no real ideal or secure way to ensure that a volume pot will stay in place. A slipped wire in the volume pot line can make the board read as 0 and make it go LOUD, which sucks.
So I'm looking at the board and thinking if there's anyway to lower the signal level as a whole to bring the signal closer to, or below, -5V. Thinking that R12, R13, or R25 are the ones I should be focusing on and increasing the value, but not sure which one to start at. I think in the past I changed R25 to something higher, but I also royally fucked that board up in an accident and can't really look back at it for reference.
I just removed the resistor from r25 on my Lethal Weapon and replaced it with wire. That resistor is just preventing the potentiometer from turning the volume all the way down. The wire is required for the ground continuity otherwise it will probably be full volume I'm guessing. Now I can make the audio completely silent.
I have a lamp matrix column out. Im 99% sure its the transistor. What are the part numbers for the matrix transistors?
Quoted from Juicerc51:I have a lamp matrix column out. Im 99% sure its the transistor. What are the part numbers for the matrix transistors?
Stamped on the transistor body. Also shown on the schematic.
Hello fellow and sister Data Easters (or are we Data Eastees)?
My Torpedo Alley DMD is not working. Everything else in the game is working and sounds are fine. What fuses or connections should I be looking at or testing?
Thanks in advance!
Quoted from pinball2020:Hello fellow and sister Data Easters (or are we Data Eastees)?
Thanks in advance!
Go to this link:
https://techniek.flipperwinkel.nl/desega/index1.htm
Go to Table of Contents.
Click on 3 -I : Score Display Problems.
This will tell you all you need to know. It will tell you why your display went dark, and it will tell you what electronic parts you need to replace. It gives part numbers. You need to know how to do board work.
This sure saved my bacon.
Quoted from radial_head:I've noticed on the Data East wide bodies I've played (Royal Rumble and GnR specifically) that the GI around the inlanes strobes especially badly when LEDs are installed. I've also noticed that on these games in particular the flashing relay controlled GI is separate from the inlanes and does not strobe at all.
I'm sure these are related, and I'd love to find a good solution to it. Any thoughts? I can't find any indication in the schematics that these GI lines are separate, but I would love to be proven wrong (or right?)
Not sure if this is what you are referring to but it was noted in the Data East Maestro thread that two DE games - GNR and RR - have an additional 5th GI string (Slingshot bulbs) that is powered from a separate source and not via the GI relay...
below is the explanation and link
Quoted from kbliznick:I am not sure how many games do this, but I do know for sure it is on Guns and Roses, possibly WWF.
The 5 pin connector has the 2 pins that control the GI relay, but on Guns and Roses the 2 leftover pins are used to power a 5th GI circuit. This circuit it actually powered by 2 diodes making rough DC voltage from the logic fuses. This powers the lamps inside the slingshots. Because it's a different source they do not go through the GI relay and are constantly lit even when the relay goes out.
I found out about this variation in GI because of the stupid place they decided to pull the power for it. If a ball gets under the slingshot and blows out a bulb (or if the sockets short, which is very likely with the way the leads almost overlap how they were stapled) then it takes out one of the paired 7A logic fuses and now the game no longer boots up.
So what I am getting to is if you did not run any lamp voltage to these 2 pins on the 5 pin connector on your board then the slingshots lamps on GNR won't work.
Quoted from Oscope:Not sure if this is what you are referring to but it was noted in the Data East Maestro thread that two DE games - GNR and RR - have an additional 5th GI string (Slingshot bulbs) that is powered from a separate source and not via the GI relay...
Wow wow wow wow yes this is exactly what I was talking about. The way that this person is describing this makes my issues sound so insanely minimal. Kudos to them to figuring this out.
I guess the now is how to create a smoother voltage for those bulbs..... any thoughts? My dumb brain says just tap into the GI before it hits the relay (or hell even before it hits the PSU) but my smart brain says "you know that definitely won't work and you're overlooking the basic ideas of the flow of electricity"
Need to replace the power board in my Checkpoint. Half the GI lights are out and I believe it’s due to a bad hack job on CN8.
What female connectors do I need for the two circled ports on this replacement Rottendog board?
The top is the CN8 and the bottom is what I believe you connect the CN9 wires to, which are direct soldered to the factory board.
