Quoted from petrieslastword:I've been trying to troubleshoot why my Monday Night Football occasionally kicks out two balls, and the only thing I'm noticing in the switch test compared to the other switches is there seems to be just a tiny delay when I press those switches from when they register. Every other switch seems to be instantaneous. It's like a half a second or less but I'm sure this is what's causing the issue. Any idea what would cause that kind of delay? I'm a little at a loss.
I tried replacing all of the capacitors on those switches with new ones but that did not fix anything.
To elaborate with a little more detail: The first switch which is the out hole switch works fine. It's the trough 3 and then each switch after that that have the delay. Replacing the capacitors on those switches did not help. It's like a half second delay after you press it and then a half second delay before it stops pressing when you let it go.
The switch is probably old and dirty. I’d replace it.
