(Topic ID: 109642)
Data East pinball club
By PinballManiac40
6 years ago
  • 2,267 posts
  • 409 Pinsiders participating
  • Latest reply 7 days ago by RexBarrington
  • Topic is favorited by 184 Pinsiders
Topic poll
“Do you have any Data East Pinball machines??”
  • Yes, I have one. 473 votes
    58%
  • I have one or more. 231 votes
    28%
  • Considering buying one or more. 74 votes
    9%
  • No, never 37 votes
    5%
(Multiple choice - 815 votes by 784 Pinsiders)
There have been 684 images uploaded to this topic. (View topic image gallery).
There are 2267 posts in this topic. You are on page 46 of 46.
#2251 12 days ago
Quoted from gdonovan:
Question, did it do anything before recapping?
Nope
#2252 12 days ago
I'd start off swapping roms or burning new set as next step.
#2253 12 days ago
Quoted from FlipperNTS:
OOOF that's a lot!
I don't have replacement parts or oscilloscope to do that major testing unfortunately.
I have verified the soldering, and gotten a second opinion on that as well...I may be screwed here...
It could be a lot but you may not need all those steps. If you have access to someone local with a similar machine it would certainly help to be able to test that board in another machine. While you can upgrade to a Pinsound you should be able to get your board repaired for a reasonable price if you run out of options.
#2254 12 days ago
WTB: Looking for a left slingshot plastic for a Time Machine.
Thanks,
Alan
#2255 12 days ago
No sound before and after recapping.
#2256 12 days ago
Quoted from Robotworkshop:
Advice on what/ where to buy?
#2257 12 days ago
Unfortunately no-one near me has a similar machine. Advice on board repair options/ services?
By the time I get a oscilloscope n such it will be past the point of just getting it repaired by someone else id guess?
#2258 12 days ago
Try a Pinsound!
#2259 12 days ago
More
I’ve had great results from Clive at Coin-op Cauldron. Been some time since I sent him anything but I was very happy with his work, price and turn around time.
#2260 11 days ago
Quoted from Jtm3:
I will update the thread with any progress/ successes as they happen.
#2261 11 days ago
Howdy, I’m looking for suggestions on Rocky & Bullwinkle. What can I put in the hole on Bullwinkle’s hand for the hat trick?
Also, the Rhino is going askew as pictured when it raises. The other pop ups work fine. I tried 3D printing a longer guide but it didn’t help.
2C492A74-1C11-4B29-AAC5-4D6B5E192409 (resized).jpegFAA5E329-CE27-4991-AE70-CA9DA4DAB0AC (resized).jpeg
#2262 11 days ago
Chck te rocky and bullwinkle thread. Some good tips and tricks and others that have similar issues
#2263 9 days ago
Quoted from cadmium:
[quoted image][quoted image]
OEM has a hex spacer and 6/32 machine screw.
I have seen replaced by a white round spacer with a plastic washer on the backside to keep the last popup from jumping past the arm plastic.
#2264 9 days ago
Quoted from vec-tor:
Thanks so much for referring the OEM parts. I ended up designing a 3D print that inserts like a standoff and seems to be working. If it's not durable enough I will use a hex spacer. Good news is that this also solved my issue with the Rhino not dropping. I guess the added weight of the hand plastic keeps it from jamming in the up position.
#2265 9 days ago
Thanks so much for referring the OEM parts. I ended up designing a 3D print that inserts like a standoff and seems to be working. If it's not durable enough I will use a hex spacer. Good news is that this also solved my issue with the Rhino not dropping. I guess the added weight of the hand plastic keeps it from jamming in the up position.[quoted image]
I would add a sleeve roller to your design.
Very nice design.
#2266 8 days ago
Anyone have an extra black lockdown bar they would sell me? Need one for my MNF.
#2267 7 days ago
Hey everyone.
Just got a Maverick home last week after about 4 good hours of gameplay it locked up. Low 5v on the power board, recapped two suspects now no +12v for some reason. No boot on the mpu. Ok...
My question is: this power supply board needs some help...but..is the 5v to the DMD supposed to come from the CN6 connector?
Pics attached. I've already ordered a replacement from marco but is this board worth sending for repair?
Thank you!
20210223_091319 (resized).jpg20210223_091252 (resized).jpg20210223_092648(0) (resized).jpg
$ 21.00
$ 150.00
$ 26.50
