Thanks.
I have, it plays a game or 2, or half game, then either scrambles or goes off. Cant seem to make it do it in command.
Thanks.
See if you can swap the ends of both ribbon cables to see if it improves at all.
The 5volt 2 pin connector at the DMD controller board is another potential problem.
Quoted from Hench4Life:Looking for a set of stand up targets for my Time Machine if anyone has some laying around..
Red triangle is tough to find. Yellow and blue are standard and most vendors have them.
Quoted from kidchrisso:Red triangle is tough to find.
Yup! I believe it is only used on Data East Time Machine.
Quoted from PinballManiac40:See if you can swap the ends of both ribbon cables to see if it improves at all.
Thx ,will try
Quoted from kidchrisso:Red triangle is tough to find. Yellow and blue are standard and most vendors have them.
Yea, that's what I've been finding...
Quoted from Hench4Life:Yea, that's what I've been finding...
Can you take one of these from Pinball Resource and make it into a triangle of the right size?
or you can carefully drill out the rivet on the old target remove the triangle, repeat drill & remove blue square or other from a new target & with proper rivets & press make your own....... ask me how I know
I bought one of these and used a dremel to make it a triangle.
https://www.pinballlife.com/data-eastsegastern-1-red-square-target-switch.html
Quoted from TecumsehPlissken:or you can carefully drill out the rivet on the old target remove the triangle, repeat drill & remove blue square or other from a new target & with proper rivets & press make your own....... ask me how I know
Drilling out the rivets is easy to do. Hammering down a new rivet is just as easy.
Quoted from cottonm4:Drilling out the rivets is easy to do. Hammering down a new rivet is just as easy.
I do not have the original target. Someone swapped the middle target back with some replacements (all round) before I got the machine. I was thinking that I'd have to modify a square target, so that's probably what I'll e d up doing... Thanks!
Quoted from apic7917:Anyone by chance have this tamp for a DE Hook? Ir is the skill shot ramp that comes off the shooter lane. I am in desperate need of one. Please let me know. Thanks you
Make inquire to @Freeplay40... I believe he has made them.
Anybody know the size and spec for these Post Studs that are common under plastics? Had a few break while rebuilding and I’m thinking it wouldnt be a bad thing to have a couple dozen on hand.
There are two sizes used in Rocky and Bullwinkle, a short one and a tall one.
Quoted from radial_head:Anybody know the size and spec for these Post Studs that are common under plastics? Had a few break while rebuilding and I’m thinking it wouldnt be a bad thing to have a couple dozen on hand.
you have options
https://www.marcospecialties.com/pinball-parts/02-4002-3
https://www.marcospecialties.com/pinball-parts/02-9899
If you want real long posts, get this and cut off the excess threads on top.
https://www.marcospecialties.com/pinball-parts/02-4425-1
Pay attention to the prices.
Guys,
Anyone here install a Boston Pinball LED dmd as a replacement for their Plasma dmd? The 128x16 dmd for my TMNT works perfectly but I am interested in having a newer (green) display, and I also like having a backup dmd. The led display instructions are very straightforward, and I'm getting good feedback from Boston Pinball customer service. My questions for you guys involve the correct placement of the display, and use/type of plastic standoffs. I always felt my display was slightly lower than it should be. Also, I noticed two hacks performed, one being a jumper wire, and the second being glued plastic standoffs (3 out of 4 glued). The standoffs do not have screws on the opposite side of lightboard. I'm assuming they need to be yanked from the board because they only rotate in place (they do not unscrew). They project 3/4" from face of board.
My questions:
1. Can you guys take a look at the pics and tell me if the display position looks correct with respect to up-down position? I still feel it's a tad lower, and I would hate installing my new DMD using incorrect mounting points. Position could also be affected by possible sagging at the lightboard where it locks in at slide bracket.
2. Can you tell (from the pics) if these plastic standoffs can be pulled from the lightboard? I'm planning to use the 3/4" long plastic spacers (provided by Boston Pinball) with bolts and nuts.
I appreciate the support!
20200523_161608 (resized).jpg20200523_171146 (resized).jpg20200523_171206 (resized).jpg20200523_174141 (resized).jpgQuoted from durgee7:Guys,
My questions:
1) Adjust/reset your backboard.
2) Measure the window ( back glass ) to frame of back box.
--- remove back glass and use the measurements to adjust the DMD brackets/standoffs...
Note: On the POTO game I drilled slots into the PCB that housed the display glass...
----- I used two screws and two spacers and was able to "fit" the display to the back glass.
Quoted from vec-tor:1) Adjust/reset your backboard.
Thanks, vec-tor! I'll do all that and more.
Hey All! Having issues with the display on Batman. It will be fine for a few games and then just goes blank. I’ve unplugged and reattached connectors, but same issue happens...will be fine for a while and then goes blank. Any suggestions where to start?
Quoted from MasterBlaster:Hey All! Having issues with the display on Batman. It will be fine for a few games and then just goes blank. I’ve unplugged and reattached connectors, but same issue happens...will be fine for a while and then goes blank. Any suggestions where to start?
Heat related, maybe? Could there be a loose solder joint somewhere?
Just try wiggling the ribbon cable on both ends next time to see it helps at all. May even try to clean the ribbon cable connections at the board with some alcohol and a new toothbrush is what I like to use to scrub the pins.
Do you have an original Data East power supply installed? Might be time to replace the smaller capacitors on the board.
Start by checking the voltages.
Before and after the display goes blank.
Solder the print headers at the power supply, all of them.
Also check the fuse clips.
Data East fuse clips are very poor quality.
Quoted from PinballManiac40:Just try wiggling the ribbon cable on both ends next time to see it helps at all. May even try to clean the ribbon cable connections at the board with some alcohol and a new toothbrush is what I like to use to scrub the pins.
No change when wiggling, so I’ll try cleaning them up with alcohol.
It has a relatively new power supply board...I think I replaced it 5-6 months ago.
The issue seems to be related to gameplay and heat buildup. I can leave it in attract mode for hours but then if people start to play it heavily then it will stop working after 20-30 minutes of play.
Quoted from cottonm4:Heat related, maybe? Could there be a loose solder joint somewhere?
Definitely seems to be heat- related, as it will do just fine in attract mode for hours.
Quoted from MasterBlaster:Definitely seems to be heat- related, as it will do just fine in attract mode for hours.
Do the connectors look ok on the power supply?
Does anybody have the color wiring for the volume pot? My machine is ungodly loud, and I think I might have slipped up and wired the pot wrong.
Hi Guys,
I have searched the forum but not found any info yet. Wondering if anyone has chromed Data East side rails and lockdown bar or if there are chromed parts that are interchangeable between DE and other brands?
I have an old LW3 that im looking to refurb although potentially the effort and cost isnt really reflective given the price point for this machine.
Steve
Quoted from CryptKeeperAUS:Hi Guys,
Steve
I just spent time looking for a Data East lock down bar and don't think anyone makes the stainless/chrome ones at all. The black ones are made and available though. I do have several older Stern machines and the lock down bar from classic Stern games like Meteor fit the Data East games as well. Unfortunately, I'm pretty sure no one makes the classic Stern lock down bars either, so you have to source out a used one, unless you want to go black.
Quoted from Pin-up:I just spent time looking for a Data East lock down bar and don't think anyone makes the stainless/chrome ones at all. The black ones are made and available though. I do have several older Stern machines and the lock down bar from classic Stern games like Meteor fit the Data East games as well. Unfortunately, I'm pretty sure no one makes the classic Stern lock down bars either, so you have to source out a used one, unless you want to go black.
So, who's selling the black bars? I'd be interested in one. Thx
Quoted from Hayfarmer:So, who's selling the black bars? I'd be interested in one. Thx
Pinball Life used to have some DE lockdown bars. This has been discussed before on a couple of forums and looks like PL has sold out.
https://www.pinballlife.com/search.html?Search=lockdown%20bar
DE standard body lock bars and the classic Stern lockdown bars and receivers will interchange.
Now, it look like your best option would be to convert over to Stern's newer dual latch lockdown system. I like the dual latch system. But the bars would be in black only, I think. So you would have to send it out to the chrome shop.
Or you might have to use this setup which I think would work. But you would have to confirm with PL.
https://www.pinballlife.com/williamsbally-lockdown-bar-lever-guide-receiver-assembly-wpcwpc-95.html
Good Luck. Lockdown bars are getting to be a challenge.
I gave up looking for a stock stainless lockdown bar for my time machine. I'm converting it to a williams wpc style lockdown bar.
Quoted from Ronnie1114:Do the connectors look ok on the power supply?
All the connectors look fine. Have played a few games at various times throughout the last few days and the issue has not replicated. Will do some testing when the issue rears it’s head again!
Target Bar on the Flugleheim Museum has stopped registering hits. I’m not at home right now so I’ll post pics tonight but when I removed the door motor bracket I found a broken wire...so I thought “that explains it”! I stripped some length off of the two ends, twisted and soldered them together and wrapped in electrical tape. Still no worky...no hits register. So I thought, okay maybe the contacts on the leaf switches need cleaned (there are two). Did the business card cleaning trick, reattached everything, still nothing. So then I tried to give the leaf switches just a little bend...nada.
As I thought more about that broken wire, I realized that the break was right at one of the zip ties which appeared to be original factory ones. So now I’m thinking that maybe that wire wasn’t broken...maybe it was meant to be cut like that? But the logic in me says that there are only two wires coming from those leafs...it has to complete the circuit somehow!
Separate question but related...what part of those leaf switches are making contact and supposed to stay closed (I assumed it was the part that faces the playfield) and how do you get the door out of there...do you have to remove all of the screws? It looked like the door would just slide out of the track from the playfield side, but there must be something on the backside of that plastic piece that is resisting removal from the topside.
Quoted from pacman11:Picked up a project TMNT and I need a 128x16 display for it. If you have one laying around that works PM. Thanks!
Post the high voltage readings from -112v, -100v, and 68v. If any are low, that also can result in what appears to be a failed DMD.
Quoted from PinballManiac40:Post the high voltage readings from -112v, -100v, and 68v. If any are low, that also can result in what appears to be a failed DMD.
I am missing the whole display.. I ordered a new power supply too.
Quoted from MasterBlaster:Target Bar on the Flugleheim Museum has stopped registering hits. I’m not at home right now so I’ll post pics tonight but when I removed the door motor bracket I found a broken wire...so I thought “that explains it”! I stripped some length off of the two ends, twisted and soldered them together and wrapped in electrical tape. Still no worky...no hits register. So I thought, okay maybe the contacts on the leaf switches need cleaned (there are two). Did the business card cleaning trick, reattached everything, still nothing. So then I tried to give the leaf switches just a little bend...nada.
This is where the wire appeared to be broken/cut so I soldered it together.
D0059997-3E7A-4A27-9321-38F27B5D9D56 (resized).jpegQuoted from pacman11:I am missing the whole display.. I ordered a new power supply too.
Long term that seems best. Capacitors on the original power supply definitely in need of replacement.
Hello, new DE owner - Tommy. Love it except...
I think I'm hitting the Skill Shot but the display reads "Skill Shot Missed" and gives me only 1 Mil. points rather than higher (20Mil I think). Weird thing is, when the ball drops in regular play I'm getting points so the ball is getting read. Somehow, I'm not getting Skill Shot. Any ideas?
Not a timing issue - I place a ball immediately in the hole. Still, "Skill Shot Missed". Some setup issue maybe? I don't see a Skill Shot adjustment.
Quoted from swfour:Hello, new DE owner - Tommy. Love it except...
If you are hitting it into the parachute drop hole, then the switch must not be working where the ball drops under the playfield.
Quoted from pacman11:Still looking for a display for my TMNT pinball, if you have an older one laying around because you replaced it with an LED one I'll buy your older display. Thanks!
https://pinside.com/pinball/forum/topic/fs-data-east-128x16-dmd
Look under the PF, the switch for the skillshot may have a loose wire. I had to reflow mine (you will see a random wire in that area) and it was working again.
Quoted from pacman11:Alright so I just got a used display and the guy said it worked. When I put it into my TMNT game nothing. I checked voltages and they were all good. Display is completely dead. What else should I be checking?
you will need to put the display chip in for your tmnt game. if you didnt have a display to begin with you probably dont have the display chip. you can order them online tho
Quoted from Clizifer:you will need to put the display chip in for your tmnt game. if you didnt have a display to begin with you probably dont have the display chip. you can order them online tho
Okay I believe it came out of a TMNT game though.. Where is this chip at? I'll check for it.. Thanks!
This page was printed from https://pinside.com/pinball/forum/topic/data-east-pinball-club/page/39 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
