Quoted from PinballManiac40:Sounds like you need new switches. The white coin door one is the interlock switch that should signal when the door is open when the switch is open. There is not a wire came loose on the back of the white one?
No there is no loose wire, that's why I took is apart. Everything seems ok.
But when I open the coin door it doesn't automatically go to audit mode
Maybe the switches need replacing?
