Quoted from Charger500:I saw the pin tonight. When you press Start it says 2 balls are missing, does a system ball check, and then it won't kick a ball to the plunger. I see a ball ready to go to the plunger. So without me taking off the glass and checking for the other two balls, what do y'all think Is the issue? I did do a nudge in case the two missing balls were somehow stuck, but nothing happened.
Quoted from Charger500:Thanks. Seems like a simple fix. I'm trying to get him to fix it. I offered to help again last night. I think they want to sell, though. Or fix it then sell. They are just not into it anymore, it seems. Shame. I want a second pin, but I don't think I want this one.
I would not rule out one ball is being trapped somewhere because of a broken rubber or plastic.
You need to run the switch tests and coils tests in order to narrow down the problem(s), otherwise we are just guessing where the problem(s) lie. If all the coils fire, likely can be a switch problem may only need to be adjusted. Then again, you can have multiple switches not working because of a single broken wire. Without knowing what all switches are not working, you can go nuts just looking the wiring over. Even a chance a coil is not firing just because of a broken wire.
I think if you can get him to let you look into it with him there, it may drive him to want to keep it longer knowing someone next door can likely help out. If you can get it working, challenge him on a few games. I really do like playing against someone more than I like playing a game by myself.
