Hello again. I had the Data East Secret Service pinball machine that had the left upper cabinet speaker humming. I took the sound board off and re soldered all of the connector pins in case there was a cold solder joint. I then switched speakers. There is still no change in the humming or the volume of it. Would this mean that I need to replace the capacitors on the sound board? Appreciate the help very much.
