I have a Data East mpu 520-5003-03 board on my workbench.
The board isn't booting like it should be.
No acid damage what so ever.
Both 5V and PIA leds come on.
I've used a old ATX computer power supply, so the voltage isn't the problem.
Even with the Data East test eprom the board isn't booting.
Here is what I've done so far.
I've replaced ALL the pia chips with known working 6821 chips.
Tested the reset generator (IC1) on another mpu board and verified it's working correctly.
Unsoldered all the small chips that have anything to do with chip select ect....
Tested them all with the chip tester. All oke.
Replaced the NE555 timer chip.
Unsoldered both 74LS244 chip and tested them, both oke.
Replaced the 74LS245 chip, which was bad.
Exchanged the cpu with a 6802 chip.
Replaced the sockets for the roms and ram.
Verified the game roms, both oke.
Checked the J5 jumper, set correctly (for a 27C512).
What can pull the reset line low (1.4V)?
I'm at a loss.....
Please help me.
Peter
