(Topic ID: 260701)
Bench Testing Data East cpu board problem
By maddog14
1 year ago
  • 14 posts
  • 7 Pinsiders participating
  • Latest reply 8 months ago by thedefog
#1 1 year ago
Bench testing data east CPU board. As soon as I attach the 5 volt from bench power supply, the 5 volt goes down to 3.8 volts.
Is a shorted out chip causing the 5 volt to get pulled down? If this is the case, is there an easy way to find out which chip?
The 5 volt and pia light are on, but no booting of cpu.
#3 1 year ago
If there is a problem with the CPU when the game is turned on, the PIA LED will usually stay on, and not turn off (and the Blanking LED will not turn on). Here is what this means:
PIA LED turns ON (and stays on), blanking LED never turns on: EPROM at location 5C and/or 5B is bad.
PIA LED turns ON, turns OFF (and stays off), blanking LED never turns on: EPROM at location 5C and/or 5B is bad (this LED sequence is very rare).
PIA LED turns ON, turns OFF, then turns ON (and stays on), and blanking LED never turns on: 6264 RAM at location 5D is bad.
Copy and pasted from flipperwinkel.
#4 1 year ago
Thanks, But that is where I was able to get the bin file for the leons test chip. So sadly for me, I was already there. While informative, I did not really follow what was stated.
Quoted from mikat11:
Yes, I have a copy of this. This information does not appear to be accurate. As stated, I have tried the Leon's test chip as well. I do appreciate the effort though. Thank you.
#5 1 year ago
Bump for more help. See original updated post.
#6 1 year ago
Quoted from maddog14:
i dont understand what you are saying is happening. Did you install Leons test eprom and nothing happens? did you make sure you had the right size eprom and the settings on the board set up for that size eprom?
#7 1 year ago
Yes.
IMO - First test would be to remove all chips that are in sockets (ROM/RAM/CPU,etc) and see if the 5v is OK.
#8 1 year ago
Quoted from Neal_W:
Yes.
Bingo. First order of business is to find out what is dragging your 5VDC down.
Any chip on the MPU board could be the culprit.
Start with the easy techniques as neal_w mentioned by removing socketed chips.
After that, leave the board powered for a while. Place your finger on each chip. Does one of them seem abnormally hot?
After that, you are left with educated guesses, and removing chips one by one.
Chris Hibler - CARGPB #31
http://ChrisHiblerPinball.com/contact
#9 1 year ago
I was afraid it would be like that. Removed all the socketed chips. Brought the voltage up a couple of tenths.
The board has been extremely worked on before. Does not look too proffesionally done. I bet it will come down to fixing previous work.
Quoted from Neal_W:
Yes.
Only a couple of tenths.
#10 1 year ago
Any of the remaining chips getting hot?
#11 1 year ago
That is unfortunately the reality that I confront with almost all boards sent to me these days.
I'll often remove all prior rework, just to establish a known baseline of board function.
#12 1 year ago
Any new progress? I'm in the same exact situation, love to hear if you solved it and how. I even started a thread before I noticed this one.
I'd love to hear more tips on how to further narrow down really tricky stuff when normal methods like heat check & diode testing for shorts on logic don't help.
I agree with Chris 100% on removing prior work. That is usually where I start.
3 weeks later
#13 1 year ago
Quoted from thedefog:
Sadly for the knowledge base, this was a customers board. I cut my loses of time and had him get a rottendog board. Boom like magic. The machine works.
I removed a few chips and got the voltage to go up a few tenths. There were several chips that were noticeably warmer. There was just too much potentially wrong with the board. For my own game, sure I would have fixed it. But how do you charge a customer for all of that time? Plus, how reliable will it be at the end of the day.
4 months later
#14 8 months ago
My situation was a bad ATX PSU I was using as bench supply.
I pretty quickly remedied the remaining issues after buying a bench supply.
$ 17.50
Playfield - Plastics
€ 95.00
FlipperLED
Professor Pinball
3,000 (OBO)
Chester, VA
Rice, MN
$ 12.50
Gweem's Mods
$ 50.00
950
Reno, NV
$ 99.00
Arcade Upkeep
