New! Dark mode!
(Topic ID: 276593)
Data East LW3 blows circuit breaker
By martymart
49 days ago
  • 3 posts
  • 2 Pinsiders participating
  • Latest reply 49 days ago by martymart
#1 49 days ago
I have just picked up a LW3. It had a power supply that was in need of repair and it did not start when I got it home. I replaced the power supply board with a working xpin board I had as spare and replace burnt connectors. When I turned the machine on it tripped the circuit breaker. I reset the circuit breaker and turned the LW3 machine back on and it worked. The next day I went through the same process with the same results.
Is this something to worry about and what should I be looking at. I did notice at times the bottom of the DMD did look a bit strange so not sure if there is something going on with the DMD / high voltage or if that was a seperate issue. I will post a photo of the DMD shortly.
#2 49 days ago
I wonder if the fuse in your panel is AFCI or GFCI - high inrush of current on cold startup could be the culprit.
I've since replaced AFCI outlets to microwave above stove and refrigerator, problems of the breakers tripping solved for me.
I know these games only use 8amps or so, maybe 10amps on a cold startup - is anything else plugged/wired to the same breaker as the LAH?
#3 49 days ago
Quoted from P1nhead:
I have just noticed that the breaker is 10amps for that circuit. I will try it on another circuit as they are all 16amps.
$ 99.00
Arcade Upkeep
2,350 (Firm)
South Bound Brook, NJ
PinSound
$ 17.50
Playfield - Plastics
Professor Pinball
$ 27.00
€ 95.00
FlipperLED
Arcade Upkeep
2,200 (OBO)
Charlton, MA
