Hi,
I'm having a problem where trough switch centre and left are activating when the flippers are pressed during switch test.
This only occurs when the switches are closed (i.e. there are balls in the trough). When they are open there is no phantom activation of the trough switches.
I have manually pressed every playfield switch on the same row and column as trough left and trough centre but they do not activate with anything other than the flippers. The activation is only seen for a split second on the DMD but it is causing problems such as 2 balls in the shooter lane and the multiball failing once a ball arrives in the shooter lane, presumably because the phantom trough switch activation is screwing up the machine logic.
Has anyone got any suggestions?
