I finally got a break from work this evening and am trying to tackle one of the last issues with a LAH I picked up a few weeks ago. I have a row of insert lights out (CN6-1). I took a quick look for any broken or disconnected wires under the playfield and couldn't find any. Then I disconnected CN6 and used a jumper from CN6-2 pin to the CN6-1 at the connector and the inserts worked so the playfield wiring is clean. I removed the board and replaced Q72 and its associated pre driver, then did a visual inspection of pin 1 for cracked solder and it looked ok (in hindsight I should have reflowed when the board was out). Reinstalled the board and the lights still don't work.
My board work skills consist of replacing transistors, connectors and remote battery packs and that's about it so I am not sure where to proceed from here.
