I'm working on a GNR and am having a transistor problem. Q5 on the PPB was shorted and locking on the automatic shooter coil. So I replaced Q5, checked the diodes on the PPB and also checked the coil diode and the coil resistance. Coil and diodes checked out okay. Powered the game up with the new Q5, coil locked on again. Q5 was hot and shorted again.
So I went back further and checked Q44 and the predriver on the CPU, they tested the same as the other transistors around them making me think they are okay. Replaced Q5 again, replaced the coil and diode just for kicks. Quickly turned on the coil power and it locked on again. Checked the wiring back from the coil back to the board, it had continuity and I could find any exposed wire for it to short.
Should I just go ahead and replace Q44 with a new TIP102 and replace the predriver and try it again even though they seemed ok? Could it be the IC that drives Q44 that has gone bad? I'm not sure where to go from here.
Thanks in advance!
