I have DE Last Action Hero and Star Wars. The LAH drop targets were not always working properly. They would not always reset. It was a mechanical issue. The brackets holding the targets were worn out. I got most new parts from Marco but the side parts are not available. If you look close the right and left side parts are the same. The holes for the rod were egg shaped from years of use. I just reversed them side to side and used the fresh holes. It works like new now. I did the same swap for SW which was not worn as much. It did improve a bit.
