well here is another crazy one. atleast its making me pull my hair out.
had this board come from a frankenstein, the machine turned on fine but i could see the battery has started to leak...
i removed the board and replaced the cpu socket, the eprom and ram sockets. the crystal, the resistors etc everything in that area that looked like it was corroded.
now i figured simple easy, i mean damn the thing worked before.
now i turn on the board. pia led is stuck on solid with no cpu ram or eprom in it. if i compare to a working board only 5 volt is lit on the working one so obviously something aint right.
if i put only the cpu chip in the board, i have clock at pin 36 and 38.
but pin 5 the vma is dead, even if i bend the pin out and then test it there is still nothing...not high or low or pulsing. cpu aint pulsing on address and data lines. compare the same thing to a working board and the vma does pulse if bend out.
i have checked all the traces sofar and cant find anything wrong. double and triple checked to see that i put the right components inplace...
anyone have some ideas? spend a few hours on this thing already and i cant give up but geez its making my head hurt.
wish there was somehere here i could take the board to who knew abit more but hey africa welcome to it.
