New! Dark mode!
(Topic ID: 214162)
Data East CN1 Burnt Help
By PINBALL-LUST
2 years ago
  • 9 posts
  • 4 Pinsiders participating
  • Latest reply 2 years ago by mikat11
#1 2 years ago
I got a Phantom of the Opera with a burnt CN1 connector on the power supply board. My question is: If I replace that connector and the pins, etc. will that fix my power board issue of game randomly restarting? I mean, what caused it to burn? Will something else cause the new parts to also burn? Should anything else be replaced when that happens? All fuses are good on the DMD. Thanks
#2 2 years ago
If it's for GI lighting, fixing it will fix GI lights that aren't lit. Not cure a reset issue.
If it's GI, they typically burn from too much current going through them. Higher than what they are rated for. Not your fault, manufacturing defect, by many manufacturers.
In home use, it probably won't burn again. If you do a good job replacing connector and pins on the board.
#3 2 years ago
Quoted from LTG:
Thanks LTG. I am using all LED lights in the game now and don't suspect it's a high GI current problem. Does this change anything? Thanks
#4 2 years ago
CN1 on the power supply has nothing to do with GI. It is for several very important systems including logic power, solenoid power and display power. I would replace header pins and connector. It might fix the resetting. Also see:
http://techniek.flipperwinkel.nl/desega/index2.htm#reset
#5 2 years ago
Quoted from wayout440:
Got it. Thanks wayout440
#7 2 years ago
Thanks.. I saw that Great Plains Electronics is currently down due to illness. I hope that guy makes a full recovery.
#8 2 years ago
GPE is a great asset to the pinball community.
#9 2 years ago
FYI for anyone interested. The CN1 on Data East power supplies are prone to burning pin 12 (ground) and pins 10 & 11 that are the AC input from the transformer and is converted to +5v DC,12vDC and -12vDC.
$ 54.99
$ 54.99
$ 21.00
Trade
Machine - For Trade
Rockaway, NJ
$ 9.00
$ 90.00
Lighting - Under Cabinet
$ 999.00
3D Tech. Pinball Parts
CzTV Mods
$ 150.00
Various Other Swag
Test item Pre-order!
$ 5,899.00
Classic Game Rooms
