(Topic ID: 255840)
Data east checkpoint dmd/reset issues
By joelw23
20 days ago
  • 84 posts
  • 5 Pinsiders participating
  • Latest reply 2 days ago by joelw23
There have been 16 images uploaded to this topic. (View topic image gallery).
There are 84 posts in this topic. You are on page 1 of 2.
#1 20 days ago
R95 didn't fix my dmd....it seems to work most of the time, but the spinning data east logo at startup looks messed up and sometimes there is nothing on the dmd during play.. also random resets or dmd freezes during a game.
#2 20 days ago
0BA55CCE-6CA0-4FD0-B33D-B2A24EFBF80B (resized).jpeg9795CE39-15C2-46A6-9BED-A31BC4BC5A07 (resized).jpegAA4E2B0C-431B-406D-A18A-3EBCF25B7BC1 (resized).jpeg
#3 20 days ago
Power supply issue maybe??
#4 20 days ago
The dots look well lit. Looks like a data issue. Any improvements if you reseat both ends of the DMD ribbon cable at the MPU and at the DMD? Make sure all the male header pins on the boards are straight, not bent, as you remove the ribbon cable ends.
#5 20 days ago
I’ve reseated the ribbon cable a few times now...maybe it’s bad???
#6 20 days ago
Where pin 1 of the ribbon is on the other end of the ribbon cable. Have to swap it on both ends so that it is connected correctly.
#7 20 days ago
Quoted from PinballManiac40:
?? Are you saying it’s connected backwards on one end?.
#8 20 days ago
NO. I am saying to swap the orientation of the cable on both ends, so the red pin 1 is on the other end of the connector. Trying to help prove this is a cable issue or not.
#9 20 days ago
Got it! Will try that tomorrow!
#10 19 days ago
Quoted from joelw23:
The Data East’s are counterintuitive. You’d think the connector is the same on both ends, but sometimes pin 1 from the MPU might not be the same end as pin 1 on the DMD. I hooked it up wrong on my DE Alphanumeric and it makes the display do weird stuff.
It’s very hard to picture, so if your cable has one of the sides colored (mine didn’t) make sure the color for pin 1 meets Pin 1 on the other side. An example being that on Monday Night Football the cable actually had to be twisted 180° to be connected properly and it made NO sense.
#11 19 days ago
If the ribbon cable was wrong on one end, there would be nothing on the display.
What I am after if trying to see if we can prove one Data line is missing data due to a one or two bad pin connections in the ribbon cable.
Very good chance the problem is elsewhere.
#12 19 days ago
1196C254-47C8-4518-B3CF-59F938A9DA01 (resized).jpegE6CA2FC4-03ED-4043-A592-3797027206D3 (resized).jpeg4637CBED-4232-4C3C-A600-9E5B0BA57F7B (resized).jpeg7571B603-7C51-4061-A2FF-26A61CD1DE90 (resized).jpeg
#13 19 days ago
same issues.
#14 19 days ago
I would have to believe the ribbon cable is not an issue here. You still have some animations freezing up even with the cable oriented this other way?
#15 19 days ago
that is correct.
#16 19 days ago
Also there were no broken or bent header pins on the DMD nor the MPU?
Is this the only DE game you have?
#17 19 days ago
correct...no broken or bent pins...
yes it is...this is my first pinball machine.
#18 19 days ago
i just played a few games and noticed that it doesn't always give/show the skill shot animation(usually on the 1st ball) and also will score points on the dmd, but then lock up and not add any points for the rest of the game until the 3rd ball is drained....
sometimes goes completely blank too until you power down and power back up the machine.
#19 19 days ago
Sill.may be worth trying another ribbon cable.
#20 19 days ago
ok..i'll have to order one.
#21 19 days ago
A computer ribbon cable will work just to test if it is the same number of pins.
#22 19 days ago
Not sure if this is the correct number of pins on the bottom right ribbon cable for your Data East game.
http://docentelectronics.com/httpdocs/AmusementGames/Pinball/DataEastPinball.htm
The computer ribbon cables I found with the strain relief usually cause intermittent issues. Many pinball supply shops are selling these type.
#23 19 days ago
thank you..i ordered a new cable...we'll see if that fixes the issues!
#24 19 days ago
I hope so since you were seeing something slightly different when you swapped the orientation of the ribbon cable on both ends.
#25 18 days ago
i hope so too!
I also just noticed that the "race again" doesn't work all of the time even though it's set to factory settings which is 10 seconds...
#26 17 days ago
new ribbon cable installed and I played 5 or 6 games with no freezing/resets!!!!
The data east/checkpoint logo on boot is still messed up though and the skillshot animation seems to only come up randomly..also the 3 drop targets sometimes reset with only 2 down and the 4 drop targets only seem to reset after a ball drain.
new roms maybe? or reburn the chips i have?
#27 17 days ago
You can reburn your current one on the DMD. Make sure you are using the latest. I would even make sure the Game ROM is the latest version as well. I suggest to erase the Eprom twice before the reburn.
#28 17 days ago
know anyone that can reburn them?? pretty sure they are the newest....a01.7
#29 17 days ago
Oh, it sounded like you had the capability. Several on Pinside can do this.
I had been just buying replacements since you would have a shipping charge both ways getting someone to reburn them.
http://www.actionpinball.com/parts.php?item=ROMS059
#30 17 days ago
Ordered display and cpu chips!
#31 11 days ago
Installed cpu roms, no change...
Still need to do the display rom... I’m assuming it’s located on the back of the dmd?? Probably have to solder?
#32 11 days ago
Yes, they work together. Yes, it is on the back of the DMD and it is in an IC socket as all EPROMs, which all games are that way that do not use a USB stick to update code.
Be mindful of the direction the notch on the EPROM is pointing when removing the old display ROM.
#33 11 days ago
Thx.. will try that later today
#34 11 days ago
So..... the display chip fixed the garbled DE logo! But the display still cuts out and doesn’t show scores sometimes or what player is up next/animations.....
Maybe a power supply issue?????
#35 11 days ago
Was this a working game when you picked it up?
#37 10 days ago
Ok. I see that Pinwiki only talks about R95 being 33k ohms, but also it is important that R104 is also measuring 33k ohm +/- 5% (31350 to 34650 ohms).
Can you post the resistance readings of both R95/R104?
When you replaced R95, do you know what the resistance was before removing it from the board?
#38 9 days ago
Old r95 = 33.6
New r95 = 33.2
R104 = 33.0
#39 9 days ago
Know anyone with a TMNT, Hook, Checkpoint, DE Star Trek, or DE Batman so you can test out the DMD? Seems there might be an issue on the back of the board.
Also, there is potential for the MPU to be causing the issue.
#40 9 days ago
Ok.. I will try to find someone...
But I think it may be an mpu issue as well... just not sure what to look at
#41 9 days ago
May be only one or the other. I have not seen a MPU and a DMD fail in a single game before.
If you can't find one of those games, the MPU can be tested in 128x32 DMD game, but likely a jumper needs to be changed in order to swap from a dual eprom to single eprom game to test.
If you can't find a way to test either, I have a 128x16 DMD I can send for testing.
#42 9 days ago
Got a couple command overrun messages too
#43 9 days ago
What? Never seen such a message. Picture of this? Started with swapping ROMs?
#44 9 days ago
If it happens again I will try to get a picture...
I just did a factory reset and it seems to be working now!
#45 9 days ago
Very interesting. So then, sounded like corrupted RAM.
Consider going NVRAM to rid of those batteries forever. 124 year retention rate.
https://www.pinitech.com/products/6264_nvram.php
#46 9 days ago
How about some pictures of it working?
#47 9 days ago
Installed nvram a few minutes ago!
76F4A6DE-39F9-434D-9764-818E8EAE37C0 (resized).jpegA74F3AEA-018C-4AAD-85C7-13408B600AE4 (resized).jpegC7C3C482-6681-4339-9969-16F6BB033D87 (resized).jpeg
#48 9 days ago
Hearing sounds and seeing animations I haven’t before!!!!!
#49 9 days ago
1 issue left I think...
Skill shot doesn’t always come up.. not sure why
#50 9 days ago
I’m in for a follow. My turtles screen kept rebooting and sometimes went black. I reset all the connectors and chips and not further issues but I’m sure there is something bigger happening.
Also noticed one of my batteries is starting to go bad need to swap them out.
Do you have a definitive answer on what fixed your screen?
Professor Pinball
$ 23.00
Yorktown Parts and Equip
Gweem's Mods
$ 29.99
$ 275.00
$ 14.50
PinballElectronics.com
