I have a sound board in a Data East Rocky & Bullwinkle that is behaving strangely. At first it was wide open for volume, nothing would make a change regardless of volume control setting. I went as far as to take a new pot and a short harness so I could plug it right into the board. I was told I could remove the SSM2024 and jumper 4 of the pins with 25K resistors (2 to 4 and 5 to 7)...that didn't change it either. What did make a change was replacing both of the LM833N. When I did this, it makes the audio barely audible. If I remove one of the new 833's and put one of the pulled ones back in, leaving it with a new one and one of the originals, it is at a tolerable level, although not the best audio quality. Another note is the board was jumpered at W7 from the factory, but the book says to jumper at W6 which Idid...is it possible that causes the lower quality sound output? I guess I should be a little happy based on other threads on this topic, at least this one works to a certain degree, but I am curious if there is an issue with the SSM 2024, because you can remove it all together and it does the same thing. After this experience, it makes tuning a nitro funny car seem easy...I am open to suggestions and as always I appreciate any and all help. Thanks, Mike
