(Topic ID: 268057)
Dash 35 board: stuffed in consecutive numbering
By vec-tor
9 months ago
  • 30 posts
  • 9 Pinsiders participating
  • Latest reply 3 days ago by vec-tor
    There have been 105 images uploaded to this topic. (View topic image gallery).
    #1 9 months ago
    What do you do when all the stores are closed and you are stuck at home and you have those projects/jobs you need to get done and you decide to go anal-retentive? Why stuff a Dash 35 board with the components in numbered order.
    Parts needed
    1) A bad Bally CPU with mostly good components.
    2) A Hakko desoldering gun.
    3) A soldering pen/station.
    4) A roll of solder.
    and finally the piece de resistance,
    5) A Dash 35 PCB board.
    Part 1:
    The Resistors:
    [#1--#10]
    Resistors:
    [#11--#20]
    Resistors:
    [#21--#30]Note: R25--R27 N.U.
    That's it for today folks.
    Tune in, as it gets complected, or not.
    #2 9 months ago
    Labor of love! I can't imagine desoldering resistors for reuse =D.
    #3 9 months ago
    Resistors:
    [#31--#34] [#35--#38] pull-up resistors for PA0-PA7.
    ( top right of board )
    Note: U10 PIA PA0---PA7, truly a "workhorse" port.
    1) Drives switch strobes and 1st three dip switches.
    2) Drives lamp address & lamp data.
    3) Drives player displays #1 through#4 & display segment (BCD) data.
    #4 9 months ago
    Resistors:
    [#39--#46] resistors for U10 PB0-PB7.
    ( right side of board )
    Resistors:
    [#47--#54] playfield switch return
    #5 9 months ago
    Resistors:
    [#55--#58] playfield switch strobes ST1 through ST4
    Note: PA0 ST0 (R133) is not stuffed. ST0 is out of sequence.
    I believe this is a leftover from the prototype development
    where the PIA used four outputs for the switch strobe,
    three outputs to read the dip switches and one line as
    a serial return input.
    #6 9 months ago
    Now on to the lower right side of the CPU board.
    Resistors:
    [#59--#61] cabinet switch test input with switch strobes ST0 & ST1
    Note: (R60) ST0 is now part of the NO. sequence.
    Resistors:
    [#62--#69] cabinet switch returns. PB0--PB7
    Now on to the upper left side of the CPU board.
    Resistors:
    [#70--#73] Lamp Address
    Resistors:
    [#74--#77] Lamp Data
    Resistors:
    [#78--#79] Lamp Strobe #1 & #2
    Lamp resistors are done and now onto the Displays.
    #7 9 months ago
    Lots of axial caps and resistors -- you need to find one of these to make life much, much easier.
    Adjust the knob until the two tips are into the mounting holes, insert device into notches on top, squeeze handle - perfectly bent leads with perfect fit. OK Industries LB-300. Out of production but once in awhile can find one on ebay.
    #8 9 months ago
    Quoted from G-P-E:
    Adjust the knob until the two tips are into the mounting holes, insert device into notches on top, squeeze handle - perfectly bent leads with perfect fit. OK Industries LB-300. Out of production but once in awhile can find one on ebay. [quoted image]
    That is a cool tool.
    "You need to find one of these to make life much, much easier".
    The components are removed one by one from the damaged OEM board.
    That is why I have the Hakko desoldering gun.
    Yes it is a pain... but at least I'm "recycling" to some degree.
    #9 9 months ago
    Resistors:
    [#80--#83] Display Segment (BCD) Data
    PIA U10 PA4--PA7
    Resistor:
    [#84] #1 Display Latch Strobe
    PIA U10 PA0
    Resistor:
    [#85] #2 Display Latch Strobe
    PIA U10 PA1
    Resistor:
    [#86] #3 Display Latch Strobe
    PIA U10 PA2
    Resistor:
    [#87] #4 Display Latch Strobe
    PIA U10 PA3
    Resistor:
    [#88] #5 Display Latch Strobe
    PIA U11 PA0
    Resistor:
    [#89] Display Blanking
    #10 9 months ago
    You must be bored out of your mind.
    #11 9 months ago
    With the 1st half of the Display resistors done, the board looks like this.
    Now to finish the upper left half of the DASH-35 board.
    U11 PA1--PA7
    Resistor:
    [#90] #7th Display Digit Enable/Sound Address "E"
    Resistors:
    [#91--#92] #6th,#5th Display Digit Enable
    Resistors:
    [#93--#96] #4,#3,#2,#1 Display Digit Enable
    All done for the Displays & Lamp resistors.
    Now on to the bottom left side of the DASH-35 board.
    #12 9 months ago
    Resistors:
    [#97--#100] Momentary Solenoid/Sound Data
    U11 PB0--PB3
    Resistors:
    [#101--#104] Continuous Solenoid Data
    U11 PB4--PB7
    Note: R105 N.U. open spot from early prototype.
    Resistor:
    [#106] Solenoid Bank/Sound Select
    Finished Solenoid resistors
    Now on to more miscellaneous resistors...
    #13 9 months ago
    Nice solder work
    #14 9 months ago
    Resistor:
    [#107]
    U11 CA2 L.E.D. drive & Lamp Strobe #2
    Back to the top right side of the board.
    Resistors:
    [#108--#111] PA4--PA1 Switch Strobes ST4--ST1.
    Note: Switch Strobe ST0 not part of number sequence.
    Board update...
    Now back down to the lower left side of the board.
    Resistor:
    [#112] Bleed resistor for VR1
    Resistor:
    [#113] +43V.D.C. input or Diode for phase A/B zero crossing.
    Onto the middle of the DASH 35 board.
    Resistors:
    [#114--#117] D0--D3 Data Lines.
    To be continued...
    #15 9 months ago
    Resistors:
    [#118--#121] D4--D7 Data Lines.
    Resistors:
    [#122--#130] A0--A8 Address Lines.
    Progress update...
    Resistor:
    [#131] part of TP1
    Finally ST0 gets some love...
    Resistors:
    [#132--#133] Switch Strobe ST0
    Progress update...
    Now back down to the middle bottom of the DASH 35 board.
    Resistor:
    [#134] IRQA / IRQB
    Back to the middle top...
    Resistors:
    [#135--#136] Halt / VMA
    Resistor:
    [#137] VUA-Ø2 / Enable
    Update again...
    Back down to the left of the board again...
    The resistor journey is almost done.
    Resistors:
    [#138--#139] Q5 conditioning resistors
    Finally the last resistor...
    Resistor:
    [#140]
    Oops, no picture of the resistor.
    Note: I found interesting, the board is stuffed with R1--R3 for Q1 and ends with R138--R140 for Q5.
    ------ The board's resistors start at one point and goes around the board and ends back where it started.
    On to the next component.... The Diodes.
    To be continued...
    #16 9 months ago
    Quoted from vec-tor:
    To be continued...
    I've noticed the resistor / cap /diode designation numbering around the switches bounces around at last strobe like maybe they decided they needed more switches after the initial design but did not want to shift all the part numbering up so they count in order.
    #17 9 months ago
    Quoted from barakandl:
    I do not know if they had to keep some kind of resemblance to the original design that they had copyrighted.
    1) Four strobes for playfield switches.
    2) Three strobes for dip switches.
    3) One strobe for serial return communications.
    4) Some components no longer exist... hence the sequence jumping.
    #18 9 months ago
    That doesn't look like an ESD safe workstation.
    #19 9 months ago
    Diodes:
    [CR#1--CR#4] Switch Strobes ST1-ST4
    Diodes:
    [CR#5--CR#7] Feed to VAUX, Display Blanking, +5volt backfeed
    Diode:
    [CR#8] L.E.D.
    Diodes:
    [CR#9--CR#10] N.U.
    Diodes:
    [CR#11--CR#18] Upper Program DIP Switches
    Update
    Diodes:
    [CR#19--CR#26] Upper Middle Program DIP Switches
    Update
    Diodes:
    [CR#27--CR#34] Lower Middle Program DIP Switches
    Update
    Diodes:
    [CR#35--CR#42] Lower Program DIP Switches
    Update
    Diode:
    [CR#43] Switch Strobe ST0
    Now back down to the bottom CPU board...
    Diode:
    [CR#44 ] Diode for TP6
    Now to the middle of the CPU board...
    Diodes:
    [CR#45--CR#48] Data Lines D4-D7
    Finally
    Diode:
    [CR#49 ] Zero Crossing Detector
    Diodes Update
    Zener Diode:
    [VR#1]
    Inductors:
    [L#1--L#2]
    CPU board update, with all Resistors, Diodes, and Inductors.
    Note: at this point, it is a good practice to test the diodes for any faulty ones that may have ended
    up on the board.
    To be continued...
    #20 9 months ago
    Before you do any further semiconductor devices, please use a static mat or at minimum a wood bench / desk. I would not lay that board on the rug for any further pictures or work.
    1 month later
    #21 8 months ago
    Progress update...
    Capacitors:
    [C#1-- C#3]
    Now up to top of board
    Capacitor:
    [C#4]
    and back down...
    Capacitor:
    [C#5]
    then back up...
    Capacitors:
    [C#6-- C#7]
    now to the middle of the board...
    Capacitor:
    [C#8]
    and bottom left side...
    Capacitor:
    [C#9]
    back to the top right...
    Capacitor:
    [C#10]
    Board update, first ten caps. in place.
    On to the next set....
    back to the middle of the board...
    Capacitor:
    [C#11]
    to the bottom middle...
    Capacitors:
    [C#12--C#13]
    back to the top left, clock caps...
    Capacitors:
    [C#14--C#15]
    back down to the bottom right...
    Display Clock Freq. caps...
    Capacitors:
    [C#16--C#17]
    over to the left...
    finally Display Blanking cap.
    Capacitor:
    [C#18]
    Board update overview, capacitors
    eleven through eighteen in place.
    Break time, updates soon.
    7 months later
    #22 15 days ago
    As I was looking at an MPU repair in the wings I began thinking of this post.
    vec-tor any further progress on this journey?
    #23 15 days ago
    Quoted from emsrph:
    It has been done... I have been lost here and there...I need to finish posting. LOL.
    I started on doing a Williams re-population... only got as far as the "b" caps.
    Thanks for the thoughts emsrph.
    #24 13 days ago
    O.K. back to the Dash 35 board...
    To the upper right side, are the capacitors to the switch matrix.
    Capacitors:
    [C#19--C#22]
    Capacitors:
    [C#23--C#26]
    This completes J2 switch return capacitors.
    Now to the capacitors for the switch strobes.
    Capacitors:
    [C#27--C#30A] strobe ST1-ST4, { Note: no ST0. [C79] }
    nineteen through thirty,A in place.
    This, for the most part, completes the switch matrix capacitors to J2.
    Now on to the next set of capacitors...
    #25 12 days ago
    Continuing on, capacitors for cabinet switches for J3.
    Capacitors:
    [C#30B--C#31--C#32] Note: #30B is ST0, #31 is ST1, &#32 is SELF TEST input.
    Next, J3 switch returns.
    Capacitors:
    [C#33--C#36]
    Capacitors:
    [C#37--C#40]
    thirty,B through forty in place.
    This completes the switch matrix capacitors to J3.
    Till next time...
    #26 3 days ago
    And now to the upper left side of the Dash 35 board.
    Lamp Address
    Capacitors:
    [C#41--C#44]
    Lamp Data
    Capacitors:
    [C#45--C#48]
    Lamp Strobe #1
    Capacitor:
    [C#49]
    Lamp Strobe #2
    Capacitor:
    [C#50]
    Board overview, lamp capacitors
    forty one through fifty in place.
    This completes the first part of the capacitors to J1.
    #27 3 days ago
    O.K. now comes the long post; for the capacitors used for the display circuitry.
    Display segment (BCD) data.
    Capacitors:
    [C#51--C#54]
    Display latch strobe #1
    Capacitor:
    [#55]
    Display latch strobe #2
    Capacitor:
    [#56]
    Display latch strobe #3
    Capacitor:
    [#57]
    Display latch strobe #4
    Capacitor:
    [#58]
    Display latch strobe #5.
    Capacitor:
    [#59]
    Display blanking.
    Capacitor:
    [#60]
    Finally, Display digit enable lines.
    Note:
    This first line is a dual purpose line.
    For 6 digit displays not used, AKA sound address "E".
    For 7 digit displays used.
    Capacitor:
    [#61]
    Display digit enable lines. #6,#5.
    Capacitors:
    [C#62--C#63]
    Display digit enable lines. #4 through #1.
    Capacitors:
    [C#64--C#67]
    Board overview, Display capacitors
    fifty one through sixty seven in place.
    This completes the capacitors for the connector J1.
    The capacitor sequence is almost done.
    #28 3 days ago
    1) A bad Bally CPU
    How bad was it- any pictures? Corroded or just non-working?
    #29 3 days ago
    We had robots do this at the factory. Imagine needing 400 of these boards every day.
    #30 3 days ago
    Quoted from emsrph:
    I got a set of eight Bally boards... sorted out what was in good shape to be repaired...
    Other boards where not so good... some had good components others where badly
    hacked up.....
    This board reconstruction project components, came from two to three boards... most of the components
    where in good shape... the PCB not so much.
    $ 99.99
    $ 5,899.99
    Music City Pinball
    $ 40.99
    Lee's Parts
    $ 99.99
    Creo Pinball
    Various Other Swag
    Shoot Again Pinball
    YouBentMyWookie
    $ 47.00
    nvram.weebly.com
    $ 295.00
    The Art of Pinball
    $ 7.50
    Various Novelties
    GC Pinball
    $ 48.00
    $ 48.00
    $ 89.95
    Hookedonpinball.com
    $ 799.00
    Metal-Mods
    $ 40.00
    ArcadeArts
    $ 44.00
    Pinball Mod Co.
    $ 156.00
    Buthamburg
    FlyLand Designs
    $ 28.00
    $ 159.99
    $ 22.50
    Magazines/books
    Pinball Magazine
    $ 199.99
    $ 26.99
    Lee's Parts
    $ 84.00
    Cabinet Parts
    Pinball Inc
    $ 7,699.00
    Classic Game Rooms
