(Topic ID: 269685)
Dancing Lady Resetting when Second Player Scores 100
By austinjw1955
#1 3 years ago
We have a Dancing Lady that does the following.
1. On a multi player game 2, 3, or 4 players when the second player scores a hundred the game resets to a single player game.
2. If you play a multi player game and do not let the 2nd player score a hundred the game plays all the way thru for each player.
3. If you play a multi player game and preload the 2nd player score to 100 it will play normally and not reset the game.
Any ideas would be greatly appreciated.
Thanks,
#2 3 years ago
What do you mean by "resets to a single player game"? Do the numbered player lights above the score reels ("2nd", "3rd", "4th") for players 2-4 go out? Do the ball in play lights advance or is it more like player 1 has unlimited extra balls? Does the game ever end after the problem?
It sounds like your B/Change Players and Add Ball relay isn't firing so the Balls Played Unit stops advancing which leaves player 1 with unlimited extra balls.
/Mark
#3 3 years ago
Quoted from austinjw1955:
Does it do a complete reset so that only P1 is active, with no score?
#4 3 years ago
The h1 and h2 hold relays have to work properly .If not when adding player 2 it will reset.
#5 3 years ago
Does it act the same in all 3 scenarios no matter how the 2nd player scores the 100 points? (10 points 10 times / 100 points 1 time)
#6 3 years ago
currieddog
Yes that is what it does. I have discovered if i disconnect all the free game score pins it works fine.
#7 3 years ago
Quoted from currieddog:
Yes that is what it does. I discovered if i pulled all the plugs for free game scores it doesn't do it.
#8 3 years ago
What levels were plugged in, ie-100, 200, etc.?
#9 3 years ago
I see that this game was the first to 'feature' Decagon reels. I would check the one on P2 100s.
Cabinet Parts
Space Coast Pinball
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/dancing-lady-resetting-when-second-player-scores-100 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
