I checked the d1 diode on the f14 tomcat flipper board and it reads continuity in both directions. Thats not right is it?
Quoted from johnny77:I checked the d1 diode on the f14 tomcat flipper board and it reads continuity in both directions. Thats not right is it?
Nope it's not. It's gone, you can bury it and find its replacement!
I was gonna say, they should test and only be 1 way, but some parts should be tested out of circuit. Sounds like confirmation above that a diode is fine to test in circuit.
I don't own F-14 so I've only looked at the manual but I don't see a "D1" on either the board layout or the wiring connections in the manual. Of course, Williams manuals are known to have errors in them.
Quoted from DumbAss:I don't own F-14 so I've only looked at the manual but I don't see a "D1" on either the board layout or the wiring connections in the manual. Of course, Williams manuals are known to have errors in them.
D1 looks like a zero ohm resister/jumper. But I could be mistaken. Test the bridge rectifier just below the blown fuse.A bad bridge would blow it for sure.
Quoted from mikat11:D1 looks like a zero ohm resister/jumper. But I could be mistaken. Test the bridge rectifier just below the blown fuse.A bad bridge would blow it for sure.
That is a zero ohm jumper
Maybe D1 on the board is W1 on the diagram shown above. Seems that it would be there to power all the flippers.
It's from WPC repair but the methodology applies here.
https://www.pinwiki.com/wiki/index.php?title=Williams_WPC#Failed_Bridge_Rectifier
Quoted from DumbAss:It's from WPC repair but the methodology applies here.
This page was printed from https://pinside.com/pinball/forum/topic/d1-diode-f14-flipper-board and we tried optimising it for printing. Some page elements may have been deliberately hidden.
