Quoted from Ronnie1114:Had my friend come over and take down notes for all the drop and stand up target decals. Hopefully, she will get back to me soon and the target decals come out great. Any suggestions on the bridge rectifier readings?
Are you sure you're using the diode setting on your meter and not the resistance setting? The 1235, 707 and 101 are more like resistance readings than diode voltage readings, especially the last two (given the resistors wired across those bridges). If it's diode, at 1235 bridge 1 is showing open and they usually short to ground.
Quoted from Ronnie1114:Something got a little toasty
There are four solenoid controlled lamps on Cyclopes. One behind the "yellow" targets controlled by Q7, one behind the "blue" targets controlled by Q4 and then two "fire" lamps controlled by Q5. I believe this is one of those lamps and if locked on and burned then you have to check Q5 on the SDU.
viperrwk
