I have a cyclone that was running perfectly and now suddenly the right kicker / sling is not firing. It does score the points when hit so the leaf switches are registering. When in test mode the coil does not fire. I did notice some "machine gunning" with the kicker previously when it was working.
I replaced the coil (i know, not the most logical first step) and no luck. I do know it uses a "special" solenoid on System 11Bs that bypasses the CPU for quicker response, but i'm not sure if it has an associated fuse. Can anyone point me to that? I read somewhere the special solenoids have their own fuses but i can't figure out where those are, if they exist. I also doubt the right kicker has a single fuse only for itself but i hope i'm wrong as that would be an easy fix once i identify which one it is. Any clues or ideas would be much appreciated.
thanks for reading.
