Hi all,
As some of you know, I just picked up a project Williams Cyclone. Little by little, I'm getting the machine running.
It's always great to see a dead machine come back to life.
I have virtually no system 11 experience. Actually I'm an EM guy with a bit of SS experience.
I'm trying to fix a couple of issues that I think may be related to opto switches, and could use some guidance.
The 1st is: the drop target does not reset or score. It resets during test mode, not during game play. It does not register in switch test mode.
the 2nd is that the Mystery Wheel home switch is open (diagnostics says H 256). Display 3 is inop, so the number of errors can't be read. Also the wheel does not spin, either during game play or during test mode.
The manual states that in order to see if these are switch or cpu problems, to disconnect connectors IP8 and IP10 from the CPU and jump the associated leads as per the switch matrix. The problem is, I don't see those connectors on the CPU.
Q: 1) How can I be sure that the optics are bad vs some other issue?
2) During test, it feels like the MW motor is trying to spin, but it doesn't. Anything to check before ordering a new board and motor?
