So I've discovered that the wire gate that at the entrance of the comet ramp doesn't have the "switch actuator arm" attached to it which is the little wire on the side that runs below the pf and activates the enter comet ramp switch.
I've scoured the net and can't find one, so I'm thinking of crafting my own.
Can someone lift their pf and measure the length of this wire? I'd like the measurement from the bottom of the loop (located on the top of the wire) to the bottom of the wire, right before the angular break in the wire
I would be greatly appreciative when you have the time.
Post edited by SealClubber : Moved to Tech Help
