Hello,
Picked up a Cyclone a week or so ago. Everything works well except the Spook House drop target opto board.
I tested:
Solenoid - Kicks Target up OK
Switch Matrix - Shorted Row and Column on opto board and it registered during test mode with Molex connector attached
I narrowed it down to the opto board. I tried 'seeing' with a digital camera, but I saw nothing inside the opto housing.
I then tried to measure DC volts, and measure nothing. I literally pulled the wires off the Molex connector, no volts. I checked all the wire harnesses from playfield, and back box and they are all tight.
I measured a clean 12V at the PSU board. I looked at my schematics and it appears the 12V "logic power" goes into the MPU, then I'm lost
The wires on the opto board Molex connector are WHT/YEL (+12VDC) and BLK/YEL (GND)
I then bench-tested the opto board. The IR LED indeed lights up, but the switch contacts do not respond to me blocking the receiver LED? I am not sure, but that little transistor must be the switch to open and close the contacts going to the MPU switch matrix...
I am looking for:
1. The 12V line, where to trace from PSU to Opto
2. Any information on the opto board for bench testing (contact closure or voltage at Row/Col pins)
Thanks Everyone!
Tim
