New! Dark mode!
(Topic ID: 149130)
cyclone mystery wheel issue
By cycloneJoe
  • 11 posts
  • 5 Pinsiders participating
  • Latest reply 4 years ago by cycloneJoe
#1 4 years ago
was having problems with the mystery wheel where either the wheel would only spin a little or not at all and i would get 1111111 across the display, i put in a new opto and reheated the solder on the stepper motor board. now the wheel spins great but the correct amount doesnt show up where his finger is, the amount that shows up on the display is always 1 or 2 spots below his finger. did i not do something incorrectly? if it helps to figure out anything the new opto wasnt tall enough so i put washers under the post mounts to move the stepper motor board up closer to the wheel so it would trigger the opto, before the washers it wouldnt trip.
#2 4 years ago
some of the lights on the right side of the playfield are acting up also, dont know if this is all tied in somehow
#3 4 years ago
anyone good with cyclones?
#4 4 years ago
I know little to nothing about Cyclones, but if the actual value of the wheel is always below the one awarded in a consistent manner, have you tried just pulling the wheel off the mechanism and re-installing it to calibrate the wheel where it would be giving the awards? Not sure if that's a possibility, just trying to give you some ideas.
#5 4 years ago
i tried that, didnt work
#6 4 years ago
somebody...anybody
#7 4 years ago
Does it work correctly in test mode? You can also search on this web site for old posts that have information on testing mystery wheel .
#8 4 years ago
does the same in test mode, always 1 or 2 spots from the clowns finger
#10 4 years ago
Try reheating all the header pins on the board itself. Make sure the optic is okay and one of the 4 legs is not partially broken off. Also, the interconnector board between the backboard and the game (on the LEFT WALL inside the game) is LOADED with cold solder connections....reheat this board---it seems to solve lots of problems.
I am sure you checked to make sure wheel is spinning evenly...we ha a motor shaft slightly bent, and when wheel spun, the part that blocks the optic for half of the revolution, was actually moving out of the optic path! Todd Tuckey from TNT Amusements
#11 4 years ago
Quoted from toddtuckey:
thank you very much, i will have to give that a try
Highland Village, TX
$ 36.99
$ 29.99
$ 29.99
$ 12.00
$ 11.95
$ 18.99
$ 12.50
Gweem's Mods
$ 50.00
$ 139.00
Sparky Pinball
Metal-Mods
