The lower pop bumper on my Cyclone does not work during game play or through diagnostics. I'm new with Sys 11s and have been reading the repair guide and doing various tests tonight. I am looking for some validation on what I have done and what I intend to do.
The center pop bumper is a Special Solenoid driven by Q77. I have the same, good voltage on both coil lugs, and the coil fires when I ground the coil directly at the lug. So, the coil has power and is good. Likewise, when I ground Q77, the coil fires. Based on my understanding of the repair guide, that means everything between Q77 and the coil itself should be fine.
I still need to check the Q77 pre-driver and if that checks out, I believe that narrows my problem down to a bad 7402 TTL issue at U50.
Q76 (left pop bumper) has been replaced (before I got the game) and is working fine both in game and in diagnostics. U50 controls both Q76/Q77. Is it possible that if Q76 shorted that it damaged the 7402?
My plan is to replace the 7402 at U50. Since the coil does not fire in diagnostics, and the coil driver itself seems to be fine, I am assuming the 7402 has a bad gate, and when the CPU signals it to fire Q77, nothing happens.
I would appreciate any feedback or additional thoughts about this.
