(Topic ID: 38810)
Cyclone lighting question - Where to use #1251 lamps?
By phlflyer1
6 years ago
  • 10 posts
  • 5 Pinsiders participating
  • Latest reply 6 years ago by rpageler
#1 6 years ago
Attempting my first complete shopping of my Cyclone while I'm waiting for my main board to come back from being repaired.
I am trying to figure out where I should be using #1251 lamp(s). From what I can see, there is a black sheathed socket under the boomerang kickout that I'm pretty sure takes a #1251.
Do the other two sockets along the spookhouse subway take #1251s or should I be using #89s there? Do those sockets take either or would I be causing any potential damage by putting the wrong lamp in there?
Thanks in advance for any responses!
#2 6 years ago
3 1251's under the subway area. 89's won't cause a problem other than burn out in a few uses.
#3 6 years ago
Thanks for the confirmation on which bulbs to use. Wasn't completely sure based upon what I read so I figured someone here could set me straight.
#4 6 years ago
Technically you use 1251's in the three subway sockets. However, you can safely use them anywhere that 89's are. They are beefier and will be slightly dimmer.
7 months later
#5 6 years ago
I've used 3 blue #89 LEDs in the subway sockets. Has anyone had these blow? so far so good but it's only been a month.
#6 6 years ago
Personally, I wouldn't use an 89 LED there. It's a 13v lamp in a 25v circuit. BCs Pinball sells 1251 LEDs.
viperrwk
#7 6 years ago
I tried BCs pinball - are they legit? I cant get paypal to go through with my order - keeps bombing. I wrote them and they have not replied. Maybe ill try a phone call to BCs.
#8 6 years ago
I Need:
#1251 28.0V S.C. Bayonet (BA15s)
I think i found LEDs that will work. Please tell me if i'm missing something since these are not made for pinball in particular:
Site:
http://www.martekled.com/-strse-136/Bayonet-Based-LED-Lamp/Detail.bok
Select Lamp # and voltage (1683 24/28v) - it's a BA15s size.
And yes, they have various colors!
#9 6 years ago
If the base and voltage are correct it should work as I doubt any LED will pull more current than the equivalent incandescent. But $20 for an LED - that would be hard for me to justify. Personally, I'd just stick with the incandescents and find some type of bulb condom if I wanted it in a different color.
viperrwk
#10 6 years ago
Yeah. I thought they were six bucks but that is if you buy 500 or so. Oh well.
$ 29.99
$ 99.00
Pinball Sales
PinWoofer
$ 18.99
$ 29.99
$ 36.99
Bethlehem, PA
