Well thanks to Pinsiders I've got the Williams Cyclone up and working pretty good. The game is playable to a point. Scoring works fine, GI's work fine, you can play it but a few things still not working. The Bottom Jet Bumper, both Left and Right Slings, Boomerang, and Big Kick still do not work. All fuses checked, all transistors check, done every test you could think of. Here is the catch, about a month ago everything played fine, now these four items are not working. Checked voltage to Jet Bumpers they all read the same. Checked voltage to the other items they are all low. Have correct voltage coming off the power supply. Help!!!
