I have the opportunity to buy this machine for $400 from an estate sale. How do I know it's authentic and what goes " factor settings" mean when I power unit on? Also, the coin box key is lost. Can I get a replacement?
Quoted from Davidkamp:
I'd jump at it for $400 if there was no wear on the playfield. Good deals are usually gone in minutes, so you might be too late already.
I'm not sure what you mean by "authentic". Counterfeit pinball machines don't really exist, unlike with smaller collectibles and antiques.
The "factory settings" means that the saved settings were lost and the factory default settings were used. Usually this means there might be a battery problem, battery damage, missing batteries, faulty RAM, etc.
If the key is lost, usually it's easiest just to drill out the lock and install a new one. Locks are cheap.
Factory Settings just means the batteries are dead and it is resetting itself each time you power it on.
$400 is a steal even for a Cyclone that is not working... It's a great game that anyone can play without having to learn an entire rule set. Ramps alone are worth a couple hundred if they aren't trashed and it doesn't look like that machine is trashed.
I hope your not typing back cuz your there buying it dear god that's a steal!!!!!!!!go no more window love jst go!!
Thanks everyone. How should I transport this machine. Can I carefully load it up in my enclosed trailer with the back of machine down and of course sandwich and wrap it up with moving blankets or hire a pro?
Also where are the batteries on the cyclone machine and how much are they to purchase and can I install them?
They're just AAs.
Take the legs off, lower the backbox and put something (like cardboard) between it and the main cabinet. They're not difficult to transport.
you are wasting time. go get it. give them the money, through it in a truck bed and go. pull over then fold head down or whatever else you want to do. dont hesitate. the circuit boards in it are worth more than $400.
I usually wrap games in 80 gauge stretch wrap and pack with blankets. When the backbox folds down, I use a piece of of a swim noodle slit lengthwise (or a piece of pipe insulation) on the top edge of the backbox. Or, a couple of layers of cardboard work ok too. Padding is necessary, or you will cause damage.
With the right tools, you can move a pinball machine by yourself.
If you have never owned or worked on a pinball machine you have a bit of reading and learning to do.
The batteries and circuit boards are in the backbox. You will need to unlock the backbox, lift up the backglass panel, carefully swing it out towards you, then lower it down.
It's not a good idea just to pop some batteries in, especially if the old ones leaked. Plus, the new ones may leak. There are a few different ways to handle the battery problem. Here are a bunch of helpful links that should get you started:
http://www.ipdb.org/machine.cgi?id=617
http://www.pinwiki.com/wiki/index.php?title=Post-Purchase_Checklist
http://www.pinwiki.com/wiki/index.php?title=General
http://pinwiki.com/wiki/index.php?title=Williams_System_9_-_11
https://pinside.com/pinball/forum/topic/cleaning-and-waxing-pinball-machines-vids-guide
https://pinside.com/pinball/forum/topic/about-bullet-proofing-system-11-power-supply-vids-guide
https://pinside.com/pinball/forum/topic/vids-guide-to-upgradingrebuilding-flippers
https://pinside.com/pinball/forum/topic/vids-guide-to-rebuilding-pop-bumpers
But, yes, as the others have said, it's a good deal, so get it now, and worry about some of the minor repair details later. You'll have plenty of time to read & research later.
Cyclone is a great machine! You'll need to get into the back box (hopefully they have that key) to lay it down. I'm a big fan of just using a pool noodle on the top part of the backbox in transit, but moving pads, whatever you've got. Run some stretch wrap around it if you like (i've done it with and without). Go get a 3/8(I'm preteen sure it's 3/8) ratchet to get those legs off. then take it home!
The batteries will be in the backbox once you take off the translate. they're just standard AA batteries. Check for corrosion.
Quoted from Flake:
Isn't it 5/8"? I can't remember--I don't have my toolbox sitting next to me.
You can use an adjustable wrench in a pinch if you don't have a socket set handy. It's not quite as fast, but it will get the job done.
[edit]: It could be either 3/8" or 5/8", depending on the game or if someone replaced them at some point.
Looks like it has some bad wear on playfield if you enlarge the picture. But it is still worth $400.
You can look up youtube videos for transporting pinball machines. Batteries are not big deal and most things are fixable. Playfield wear, damaged ramps, missing parts, etc are the bigger issues.
Quoted from pinbum:
I can see wear spots where the balls drop into the inlanes from the ramps. I can't definitively tell if there is wear anywhere else.
