(Topic ID: 54473)
Cyclone Club...Members Only!
By mof
10 years ago
  • 1,794 posts
  • 241 Pinsiders participating
  • Latest reply 6 days ago by BlackbirdXX
  • Topic is favorited by 114 Pinsiders
There are 1,794 posts in this topic. You are on page 29 of 36.
#1401 1 year ago
Thanks! I have some Lexan. I also have the tools to cut and polish it at my work. I look forward to getting started on the restoration. I want to make it a one of a kind, HEP type Cyclone. I'll post here in a couple of months when I get started on it.
#1402 1 year ago
Quoted from kyle5574:
Coaster 3D prints of Comet and Cyclone from Mr_Tantrum make a great topper.
Can you elaborate further? Pics and/or links would be awesome!
Jaz
#1403 1 year ago
Quoted from Jazman:
I don't know if he's still doing them.
https://pinside.com/pinball/forum/topic/cyclone-comet-coaster
I've been planning on lighting them up and triggering the lights with the ramp inserts, but other projects are distracting me. They still look great unlit though.
#1404 1 year ago
Quoted from jazc4:
I plan on starting a full restore on a Cyclone in a couple of months. It will get LEDs, new rubbers, and either a hardtop or new playfield. What MODs are there for this game and which do you recommend? Thanks!
When I restored mine I did repainted my Ferris wheel and gave it some metal flake. Redid the ramp in a nice deep blue also….
11F90DA8-DB10-4771-B3C0-F1F27AF2ED55 (resized).jpeg11F90DA8-DB10-4771-B3C0-F1F27AF2ED55 (resized).jpegCF83673E-AC23-4733-B2F0-FF6D1D2EEC52 (resized).jpegCF83673E-AC23-4733-B2F0-FF6D1D2EEC52 (resized).jpegE7F6DF76-4929-409F-9F96-7116A3D16017 (resized).jpegE7F6DF76-4929-409F-9F96-7116A3D16017 (resized).jpeg
#1405 1 year ago
Quoted from metalkatt:
That's sweet. I will definitely do something like that.
#1406 1 year ago
I am thinking if it's possible I'd add people on the coaster. Time to search Ebay for Ronald and Nancy.
#1407 1 year ago
I love the metal flake. And that clear plastic ramp looks amazing too. Did you polish it somehow? I've tried using the stuff they recommend for car headlight covers but it doesn't seem to have done much.
#1408 1 year ago
Hoping for some assistance - my left flipper quit working in the middle of a game. The flipper button is not registering in switch test. I replaced the leaf switch and that didn’t do the trick. What else should I be looking at?
#1409 1 year ago
Quoted from mark532011:
flame polishing works, but with the risk of warping the plastic all to hell if you're not careful. i've done it myself, so if I can do it, for real anyone can.
#1410 1 year ago
Quoted from shiffdog:
If I remember right, the flipper button on System 11 doesn’t register in switch test. It’s the lane-change switch that registers, and that only registers if the flipper moves. First thing I’d do is check for voltage at the coil. Look at your flipper coil and find the two diodes next to the lugs. Each of those diodes will have a white line/band around it on one side. With the machine ON, put your multimeter in DC voltage mode, carefully touch the red lead to the outside lug on the coil on side of the diode with the band (this is where power comes in), and touch the black lead to the ground braid inside the cabinet. Should see around 50 volts on your meter.
#1411 1 year ago
Add to above: blown fuse? wire connection continuity? bad coil winding? broken EOS switch?
--------------- broken flipper components?
#1412 1 year ago
Thanks. I hadn't looked at anything much beyond the leaf switch because I didn't realize that the flipper button itself isn't actually what's registering in switch test. Now it makes a little more sense. I recently did a flipper rebuild so hopefully nothing is wrong with the flipper mechs - maybe it's just a bad solder job by me. Can I rule out a blown fuse if one flipper is working, or are the flippers on separate fuses?
#1413 1 year ago
Those ramps are brand new, no flame polishing required.
#1414 1 year ago
There is a fuse for each flipper, F5 and F6 on the Aux Power Driver board.
#1415 1 year ago
I just replaced mine also. The difference is pretty striking. So clear. The fit wasn’t exactly like the original, and required some work to get the fit right. I can’t fit my front pop bumper cap on. No room for it now. I’m ordering the one that has one side cut, for TAF and other tight spots. Very happy with the clarity tho. The drop hole on the Comet ramp was too small and the ball got stuck in it. I used a dremel and made it slightly wider. Someday a new pf!
C7C7F1C8-66D1-428E-8AAD-45BDB9D1E8D2 (resized).jpegC7C7F1C8-66D1-428E-8AAD-45BDB9D1E8D2 (resized).jpeg
#1416 1 year ago
I have started work on my Cyclone. The first step was to scan it in and I now have a 600dpi record of what the playfield looked like, dirt and all, just in case something happened. I have Photoshop Elements and I have to say I was really impressed with its ability to merge the scans together (I used a standard Epson Perfection 8.5 x 11 scanner laying on the playfield) - i just gave it the overlapping pics and it stitched them together and even adjusted the colors to match it all.
I think I will do another one when I get the dirt and swirls off - if anyone is interested I can send them the full sized image (2gb) (but its pretty dirty, see below)
Cyclone-Playfield-Full-Dirty (resized).jpgCyclone-Playfield-Full-Dirty (resized).jpg
#1417 1 year ago
Hi Guys, I am having issues locating a part for my cyclone. The ball gate for the Ferris wheel part number A-12160. Any help would be awesome. Cheers
PXL_20220830_130332752.MP (resized).jpgPXL_20220830_130332752.MP (resized).jpg
#1418 1 year ago
Quoted from Dukznutz:
You will likely need to buy some music wire and make one. Lowes carries it in their bins. Search it before you go and it will give you the location in the store.
https://www.lowes.com/pd/Hillman-6-in-Aluminum-Music-Wire/3478173
#1419 1 year ago
I think I will do another one when I get the dirt and swirls off - if anyone is interested I can send them the full sized image (2gb) (but its pretty dirty, see below)[quoted image]
What did you use to scan it?
#1420 1 year ago
Quoted from jazc4:
I have an epson perfection scanner. I removed the plastic flashing around the edge which allows the glass to touch the playfield. This allows for good quality scans. Here is a piece of my original, scanned at 600dpi.
original scanoriginal scan
The big problem is of course that it is only 8.5 x 11 and the scans need to be stitched together. I did the automated route and in checking it, its pretty close. The overall height of the graphic as measured on the playfield is 37.75 inches. As measured on my graphic, it is 37.7
However I did notice where the software messed up at the edges though. Here is the extreme top. Note how the software matched up down at the rollovers but didn't get the very top. I will have to do it manually I guess.Cyclone topCyclone top
#1421 1 year ago
However I did notice where the software messed up at the edges though. Here is the extreme top. Note how the software matched up down at the rollovers but didn't get the very top. I will have to do it manually I guess.[quoted image]
That's freakin cool. I want to learn how to do this.
#1422 1 year ago
Quoted from jazc4:
I posted some more detail in this thread, when I first started it was blurry but now its working quite well. https://pinside.com/pinball/forum/topic/scanner-alternative-to-hp
I used it to scan in my whole Ice-Revue, recreate the artwork in photoshop and print out a "soft top" that I stuck on and coverd with clear, as I had a lot of trouble with painting
https://pinside.com/pinball/forum/topic/total-restore-of-an-ice-revue/page/3#post-6545018
#1423 1 year ago
I have a scan of a repro playfield if you need
#1424 1 year ago
Quoted from ClarkKent:
I could use that.
#1425 1 year ago
the top of my playfield is worn away around the 1-2-3 lights (see picture above) so I decided that when I put on a replacement graphic I would add in our family. I took pics of us looking up and patched them in. Its back at the back end of the playfield so not real noticable but I think its fun for our family!
#1426 1 year ago
That's freakin awesome!
#1427 1 year ago
Easily one of the coolest and most creative mods i've seen! Bravo!
#1428 1 year ago
It is a very cool mod @mark532011. For another, I noticed coasterdynamix now makes an electroluminescent "Cyclone" sign 7.5" long:
https://www.coasterdynamix.com/products/cyclone-electroluminescent-sign
#1429 1 year ago
That's cool. where are you going to install it?
#1430 1 year ago
that would be a cool centerpiece of a custom topper!
#1431 1 year ago
Can you 3D print a Cyclone rollercoaster to fit the top of the backbox? The lighted sign would look cool on that!
#1432 1 year ago
Quoted from Bax1:
It reminds me of those lighted graphics in car door sills. No door sills here, so I don't know. It'd look cool above the coin box, but then who'd see it?
#1433 1 year ago
Quoted from clodpole:
your balls would
#1434 1 year ago
Quoted from Bax1:
your balls would
Hah! I get to see the real Cyclone in a week - on Coney Island. Maybe it'll inspire me to think of a location for the cool little lighted sign.
#1435 1 year ago
let us know where it goes. I like the looks of it but just don't see where it can go.
1 month later
#1436 1 year ago
This might be an odd question, but i'll ask anyway.
I will most likely be bringing my cyclone home from my parents house and swapping it out with game show for my father.
It's a reimport i've had for a pretty long time.
So, the wheel is not real. It's more a light show.
The decal is on the glass. Had me fooled until i had 2 cyclones at the same time and i was troubleshooting one using the other and had the glass out of both.
Now that the stepper board, motor and wheel can be purchased, could i retrofit the real wheel in?
Rom change?
The reality is that the fake wheel is most likely less troublesome, but i'm curious anyway.
#1437 1 year ago
Quoted from jcar302:
Rom change?
I would assume it to be an easy swap. Even if there are board issues on that "solenoid" (drives from a sol line), it should be an easy fix. You could test the line before hand with a probe.
#1438 1 year ago
Not sure if the game is supposed to do this, any help appreciated.
When ball is coming down the inlane, the ball bounces on the flipper rubber really messing with timing of the shots. Is this typical on this game?
#1439 1 year ago
Quoted from JakePG:
That's called "ball hop" or "flipper hop" Do a search in Pinside, it's been a subject for years. You will find good suggestions.
#1440 1 year ago
Quoted from JakePG:
Take a look at Cliffy’s Enhanced Flipper Return Frames. Cyclone uses common frames, 8108-L and 8108-R.
https://www.passionforpinball.com/FlipFrames.htm
#1441 1 year ago
Perfect. Thanks a lot. I'll try out those cliffys
#1442 1 year ago
Quoted from Tomass:
Thanks, when i bring it home, i might give it a try.
#1443 1 year ago
Rom change?
There are pictures of this on IPDB claiming it's the Japanese export version. I'd keep it as is and have something unique. There can't be that many of them.
#1444 1 year ago
Quoted from JeffZee:
I've had that thought as well.
No matter what i did, i was never going to permanently alter it.
The reality is that it's just an idea at this point.
Who knows, i may not keep it that long after i shop it out again.
When i get it here (my parents only live a couple miles away), i'll take some pics so everyone can see what it looks like.
Because i remember the first time i noticed it, i was seriously confused.
#1445 1 year ago
I was not aware of this version. You will need to check for the proper wiring and other things before putting one in. There is a separate board that runs the stepper too. Probably a lot involved. Post up pics if you pick it up.
#1446 1 year ago
I have a question about lights. I am redoing some missing stuff under the playfield.
Page 44 of the manual says most of the medium socket lamps are #89 flashlamps. Easy enough, but number 15 (Boomerang Flasher) is a #1251
However, under the playfield there are 3 lamps along that insert. Are they all #1251's or just the one on the end?
https://www.ipdb.org/files/617/Williams_1988_Cyclone_Manual_Schematics.pdf
#1447 1 year ago
I believe all three are 1251's
-Paul
#1448 1 year ago
whoever worked on it didn't pay much attention. the bulbs are screwy in this thing. There is a mixture of 1251's and 89's all over. Weird because the 1251's are 28v so i wouldn't think they would even light in a 89 socket
#1449 1 year ago
There are 28v lights in the flashers in the subway if I remember correctly.
#1450 1 year ago
Moving in with my resto. I am looking for help on mounting the center drop target opto board. Does anyone have a pic if theirs?
The board looks to need washers but is too sloppy. The manual says it needs a spring but there is too little space for one. The manual is difficult to decypher on this.
reading it in order, it sounds like:
washer
e-ring
spring
washer
opto-board
spring
washer
e-ring
grommet
but the washer has to be at the bottom touching the drop target as it is the right size to slide in the groove and the opto board doesn't fit where the shaft changes size so there has to be a washer there.
7F9B47C4-FB97-4B2B-82B2-1ACE7921DB7F (resized).jpeg7F9B47C4-FB97-4B2B-82B2-1ACE7921DB7F (resized).jpegF874810F-6AC6-42FF-A820-C80EEC6EE71D (resized).jpegF874810F-6AC6-42FF-A820-C80EEC6EE71D (resized).jpeg
Screenshot 2022-11-23 173929 (resized).pngScreenshot 2022-11-23 173929 (resized).png
$ 69.00
Pinball Pimp
3,200 (Firm)
Collegeville, PA
$ 27.00
$ 2.50
$ 36.95
$ 95.00
Pinball Mod Co.
$ 19.99
$ 11.95
$ 29.99
Daddio's 3D Printed Mods
$ 170.00
Displays
Digipinball Shop
3,650
Copley, OH
$ 39.99
$ 69.00
Pinball Pimp
$ 18.95
This page was printed from https://pinside.com/pinball/forum/topic/cyclone-clubmembers-only/page/29 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
