(Topic ID: 285010)
Cyclone- 3 under playfield Flashers Blow Simultaneously
By pindude80
#1 3 years ago
I bought a Cyclone a few years back and a lot of the GI bulbs were burnt out. I finally got around to fixing it. I pulled all of the playfield plastics and replaced all of the incandescent bulbs with LEDs in the GI. I knew some of the flashers were out but not as many as I found when I was changing the GI bulbs. I replaced all of the flasher bulbs that were bad with new # 89 incandescent flasher bulbs I had. Everything went well except for the three flashers under the playfield that are daisy-chained together blinked two or three times in test mode then went out. I lifted the playfield and saw all three of the flashers were blown.
Does anyone know what would cause the three flasher bulbs to burn out almost immediately and / or what I can do to diagnose and fix the problem? I have attached a picture of the three flashers in question. About 50% or more of the GI was burnt out and as I mentioned earlier a lot of the flashers were as well.
Is there possibly a bigger issue responsible for the amount of burnt out GI and flashers? The guy I got it off of did a playfield swap and you would think he would have at minimum replaced the burnt out GI bulbs and not put burnt out bulbs back in when he did the swap but who knows I guess.
Thanks in advance for any advice and suggestions.
#2 3 years ago
The Boomerang flashers need to be #1251 lamps (28V).
#3 3 years ago
Quoted from Inkochnito:
The Boomerang flashers need to be #1251 lamps (28V).[quoted image]
Good find!
I was wondering what the "1251" on the display meant next to "boomerang" in test mode. None of the other flashers had any numbers with them in test mode.
I wonder why the boomerang flashers run at a different voltage?
Thank you very much for letting me know that I had the wrong bulbs in it!
#4 3 years ago
The voltage is the same (about 24V).
The "on" time is longer at the Boomerang.
That's why a 12V bulb burns right away after a few seconds.
Trade
Machine - For Trade
Belfast, NY
$ 69.00
Pinball Pimp
$ 11.95
$ 19.99
$ 27.00
$ 29.99
Daddio's 3D Printed Mods
$ 2.50
$ 170.00
Displays
Digipinball Shop
$ 69.00
Pinball Pimp
$ 39.99
$ 12.50
RoyGBev Pinball
3,200
Cumming, GA
$ 18.95
$ 36.95
