I have a CV that has no sound during game play, but all of the sounds seem to work fine in test mode. Any ideas on what to check?
Connectors first. Re-seat everything. Inspect the wires going into the connectors as well as the connector pins on the boards to make sure none of them are loose. 9 times out of 10 it is just a connector issue or frayed ribbon cable, sometimes you'll need to reflow solder on the pins if they're cracked/dried.
If that doesn't work, then it could be a number of things, but check that first.
This page was printed from https://pinside.com/pinball/forum/topic/cv-no-sound-while-playing and we tried optimising it for printing. Some page elements may have been deliberately hidden.
