Quoted from Kineticross:For completion's sake, here are the major stacks you are able to accomplish in Cirqus Voltaire:
- Ringmaster + Highwire + Strike-an-Arc
- Ringmaster + Juggler
- Ringmaster + Strike-an-Arc
- Highwire + Strike-an-Arc
- Neon + Juggler (this multiball is EPIC; but it takes pure luck to activate it. When Juggler multi and side show is lit, Neon can be stacked, which allows for huge scores)
This exactly. I almost get pissed off if I don't do the first one for the first Frenzy.
It's been said that you can stack SaA, High, and a RM, and if you previously had juggler ready for ball three, once you drain the second last ball in MB, shoot the juggle before the MB times out, and you restart the previous three and add juggler to it. I have tried and tried this, and if it is possible, the window must be uber tight, as I have never been able to do this. tough to keep trying when you can just hit the ramp immediately after MB and cash out the super duper jackpots.
As for Neon - your machine gives Neon?? you lucky bastard. Home roms make it next to impossible to get. I've seen it I believe 7 times in the 3.5 years I have owned it. Wicked cool though when it happens.
